I recently crashed my computer and re-programmed it. the speakers have no sound. control panel will not let me access my speakers.
  • 300 Answers
Without knowing the make of the machine it will be hard to give specific steps. But, if you have a set of restore CD's you should be able to try reloading the sound drivers from that CD or the manufacturer CD if you have upgraded the card.
You can open the device manager by going to Start > Run > type devmgmt.msc and press enter. In the device Manager you should see something that says unknown device with a yellow ! beside it. You can insert the restore cd or the manufacturer cd and click reinstall driver and when asked for the file... point it toward the cd drive and that should help.
*** Make sure that if you use the restore cd that you remove it from the cd before restarting the machine***
Thanks
Posted on Jul 20, 2008
My sound card is crashed.help!!
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 26, 2011 | Lexicon Omega Pro Studio External Sound...
My computer crashed recently and it deleted everything off my harddrive. Now my computer is saying no audio device, and I don't know what to do. I tried to unplugg them and see what happens, but nothing. I...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
Mar 08, 2011 | Kinyo Audio Zone 2.0 Sound System Computer...
My skype is telling me i needs to access my sound card and cant. my itunes isnt working either. This was all just all of a sudden. I dont know what to do.
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s for this device
to do this right click on the ? x ! select reinstall driver
the drivers might have been corrupted by something or you might have got a virus run your antivrus program
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers also
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 11, 2011 | Dell (8H390) Sound Card
Computer crashed, reloaded all software. Window xp home edition. Now speakers do not play. Did before crash. Tech says it should play. I have done all the test he recomends and still nothing. What am I...
You may need to download the software for the sound card, it is not part of the program in many recovery disks, go to the support site for your computer, Dell, HP, whatever the manufacturer is and load up software and driver downloads by the model or service tag number of your computer. Also go tot he start menu (lower left of tray) and click on "Control Panel", in the next window click on "Sounds, Speech and Audio Devices" then check to see that the volume is turned up on the sound or it is not muted.
Nov 29, 2010 | Gateway Edison Computer Speakers
No sound speaker system not working do i have download a program to get system to work
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 21, 2010 | Boston Acoustics BA735 Computer Speakers
What can i do if my kinyo speakers dont work since my computer crash and the coumputer cant fine enoght data to instal that hardwer
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 25, 2010 | Kinyo PS-107 Computer Speakers
Low speaker volume and loud feedback noises
i have special driver for you , where do you live ??
Jan 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
No sound when i put in cd or dvd was working ok untill my computer crashed
check the following
Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
hope this can help
goodluck
JABEMS
Nov 13, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Asending sound
dear sir
it's sound setting given in to sound control panel may be it's set to holl or equalizar is set miss match and chek yr sound pin which connected is proper or not otherwise just put a wizard given in control panel or chek yr sound drviers it;s help u...:)
thanks
please vote
jo_Chinmay
Jan 05, 2009 | Harman Kardon HK695 Computer Speakers
My Control Panel crashes when I switch views.
Please try to open control panel in safe mode and let me know what happens?
you can go to safe mode by tapping f8 when computer is starting up.
If safe mode works fine then any of the the start up item, third party service,spyware or useraccount is causing the problem.
To find if startup item is causing the problem we need to use the msconfig command on run and click on startup item and disable all apply close click and restart on prompt and try to open control panel on normal mode.
please let me know the safe mode status.
Aug 19, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
