Question about Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305
My Garmin won't download to the computer
  • lampardf Jul 20, 2008
    I bought the Garmin a year ago. It worked fine until last week. Now no information will download to the computer. The screen says that I should download the information on email and send it to Garmin. But I can't get any information to send. I have not seen any recent updates to thesystem so it could be a lack of update. But this should not block the downloading. Do you have any other suggestions?
    President:
  • 2,712 Answers
Do u still have the correct serial code? Without that u couldnt download anything..also note that Garmin doesnt give the new downloads for free..
Posted on Jul 20, 2008
    Scholar:
  • 191 Answers
How are you connecting the Garmin tell me the way you are doing.
  • Garmin Master
  • 13,433 Answers
You need to make sure the drivers and software is up to date.
  • 2 more comments
  • Ekse Jul 20, 2008
    connect the garmin, then right click on my computer, select manage, then on the left side select device manager.
    now on the right window with all the devices note any with a yellow ! or ? mark. see if you can find your garmin there if your garmin has ? or ! then most likely the drivers are not installed.
  • Ekse Jul 20, 2008
    everything is available here
  • Ekse Jul 20, 2008
    make sure you update all the software from the page
    1. web update
    2. training software
    3. driver
  • Ekse Jul 20, 2008
4 Suggested Answers
SOURCE: My Garmin forerunner 305 will not turn on.
I have had the same problem. To fix it, I simultaneously hold down the "mode" and "reset" buttons for about 10 seconds. After releasing the buttons I power it up as normal. This has worked both times it has happened, and I got this fix from the Garmin website. My mileage totals are still in the history.
Posted on Feb 26, 2009
  • 84 Answers
SOURCE: change Battery in garmin forerunner
Might not be the battery.My wife's was always powering off during runs. Then it would not power on at all. There was a connection inside that wasn't making contact. But first First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some brass fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps.Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker.Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs more that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag.Let the unit sit over night. In the morning remove the tape.
Posted on Jun 09, 2009
SOURCE: Garmin Forerunner 305. Problem receiving activities and courses
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Posted on Jul 31, 2010
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
Apr 28, 2011 | Garmin Forerunner 305 GPS Receiver
I have bought a new computer, windows 7. I cannot install driver for forerunner 305.
Glad to HELP YOU!
It's a well-known issue between Windows 7 and Garmin Forerunner.
Garmin company says it's a compatibility issue concerning the USB connection between the computer and the device and usually they recommend to be an Intel Chipset.
Try to download and install using the latest drivers available on their site on WIN 7 and Forerunner 305.m You have them ALL here and the USB driver was released this year and it's the last one on that list.
GOOD LUCK!
Mar 26, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
I have a new Forerunner 305 and it transfered my first workout to the computer but will no longer do so. The device says "Transfer Complete" however the computer states "There was a problem communicating...
I've just experienced a similar issue for the first time since owning my Garmin 305 Forerunner. Slight difference in my circumstance is that the device itself doesn't show the activity in its history, despite having displayed apparently accurate readings during the activity iteself. Bizarre isuee, and although it's my first issue with this otherwise great device, it does destroy your faith in the unit.
Nov 08, 2009 | Garmin Forerunner 305 GPS Receiver
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
Sep 21, 2009 | Garmin Forerunner 305 GPS Receiver
GARMIN 305 Forerunner wont transfer data to PC
Mine won't download workout to computer for a while now. It comes up with a bunch of gibberish and asks you to copy the error to clip board and e-mail it to tech support. Well I did that twice and never heard back. I also called twice but the reponse time is very slow - over 15 minutes. When I finally got someone they said they would have to transfer me to someone who handles software issues and it would be another 20 minute wait. Geezzz. Can anybody help? Even when I reinstalled I still got the error. I am using Windows XP. JB
May 18, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Forerunner 305
my htc phone programs i had on my computer was interupting my connection between watch and computer,so as soon as i uninstalled the htc software it started working again, hope that helps
Sep 15, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
