Question about Lands Phones
How do I set up my wifi on my iphone to connect to my wireless router at home?
    Problem Solver:
  • 13 Answers
If you have your wireless secured you will need the security code you typed in when setting up your router.
Posted on Jul 20, 2008
I can not find the password/passphrase for wi-fi
its a setting on your iphone, my iphone has a wifi timeout set on it so if wifi data is not used it will power off the wifi to save battery. you can disable the option in iphone settings.
Apr 04, 2013 | Buffalo Technology Whr-g300n Wireless-n...
My iphone 4 has become slow to connect to my Netgear DGNDv2 modem router. The connection used to be really quick but now I have to repeatedly tap the refresh button on the iphone to get it t connect.
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Mar 09, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
My iphone 4s will connect to my wifi but cant download anything new - yet works fine on 3G
check the settings of the wifi ( make sure thats DHCP) in the wifi menu
good luck
Feb 13, 2013 | Apple iPhone 3G
Iphone can't use home wifi
just confirm if the password you have for internet is correct or not.
Now do the manual security settings in your phone same as of router. Like security type & password both.
check for the phone wi-fi, and use it.
Jan 21, 2012 | Linksys WRT54G2 Wireless Router
Random wi-fi dropping
Go to the linksys website, see if they have a firmware flash for the router, that may help in some connectivity issues. You may also find that the ipad/iphone may drop connections when battery levels are low
Nov 02, 2011 | Linksys WRT54G2 Wireless Router
I cant join my wireless router with my iphone?
what you want to do is go to your computer and make sure that your wireless router is discoverable because if its not your iPhone will not detect it also what you want to do is make sure that your iPhone's WiFi is enabled to do that go to settings WiFi and enable and remember when you try to connect to enter the password right and if all that doesn't work try holding the home and power button and wait till it turns off and boots up.
May 21, 2011 | Computers & Internet
Trying to connect my iPhone 4 to my WGT624 v3 router. My iPhone is detecting the network, but i'm getting the message "unable to join the network" .
Hi chaps,
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2. Reconfigure you Wifi network by going to setting ---->under choose a network---> others-----> Enter your SSID name (seen at the back of your router) ----->under the security tab selet the same encyrption standard as that of your router which you can see when you log in to the router (usually router IP 192.168.1.1) ---->setup ------>wireless setting----> security option. This one helps you to join your home wifi as soon as you enter your home.
Dec 29, 2010 | NetGear WGT624 Wireless Router
My iphone 3gs cannot connect to wifi network at home. i am using linksys wrt100 wireless router.
A wireless client has to support WPS ( wi-fi protected service) function in order to use to add the client to your WPS enabled Wireless Router. check the iphone user manual of your wireless client to see whether it supports the WPS function. If your wireless client does not support the WPS function, you have to configure your wireless client manually so it has the same SSID and wireless security settings, you could also go into the advanced wireless settings and enable WPS ( push and connect ) if your router has this option this is sort of specifically for things like mobile/cellular phones and ipods...hope this helps please vote thanks
Aug 06, 2010 | Linksys RangePlus WRT100 Wireless Router
I am not able to connect my iphone to my home wifi (which uses dlink-DIR 615). I am able to connect my iphone with other unsecured wireless networks. But, mine is a secured one (WPA). Do I have to change...
No, just like when you set up a wireless connection for the first time with a home network, you need to input the network key. As long as you have the key handy, it should work!! For example, when I connect my iPhone to home network, I see my network name "553c" and I "touch" that and it asks what kind of security it has (unless this has changed, my iPhone is 1st generation) so I pick WEP (you will pick WPA of course : ) )and then it prompts for the network key. Hope this helps!!
Mar 27, 2010 | D-Link DIR-615 Wireless Router
Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
Yep, I had the same problem with my iPhone as well (32GB 3GS).
Had the signal NO problem for about a week then POOF it was gone. WTF?
Prowled the boards looking for a solution.
Tried resetting the phone, resetting the Wi-Fi, switching airplane mode on and off, forgetting the network, etc.
HERE'S YOUR SOLUTION :
Go unplug your wireless router's power cord.
Wait 30 seconds.
Plug it back in.
Your iPhone will reconnect, and you'll be back in business.
Jack
Jul 15, 2007 | Apple iPhone Smartphone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
