I have an 05 Focus and recently changed the battery. Now the radio needs a code that I cannot find in the Service Manual or Radio Booklet. The model number is M039978.
Any help is appreciated.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio. The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Ford servicecentre and get them to enter this code for you.
Sometimes, the radio code is label, in back side of the radio; you need take off the radio for check it. Other times this code is in the last page from owners manual.
If you can't find it, maybe need call to the Ford dealer with your VIN number and they send to you (sometimes need pay for this service).
hi, if your radio code for example is 8156 you push the no1 button 8 times then no2 button 1 times then no3 button 5 times then no4 button 6 times then hold down the number 6 button for about 5 seconds and the radio code will store automatacly and start up. hope this helps you regards
The radio goes in safe mode when the battery gets disconnected, or if for some reason the radio lost power connection.
To get the radio out of safe mode you will need the anti theft code.
This is available with car documentation, in first page of the in car entertainment booklet, or on first page of the car booklet (not the car manual).
Once you have got the code, do the following:
Hold down both the AM/FM and the SCAN button at the same time, until the display shows "1000".
Use the buttons 1,2,3,4 to change each of the digits until you get displayed the same code as printed on documentation (ensure that it is the right one).
On some radio (programmable models), the default code is "1111" or "1234".
Press and hold the AM/FM and SCAN buttons again until the radio is starting.
If you fail twice the code, the radio will lock up in safe mode, and you won't be able to enter the code again.
If the radio is locked, or if the code is lost, the unlock can be done at the nearest car dealer, usually for a small fee, or for free.
