Matsui LM20N2 on-off button
The red on/off button is loose and has trouble engaging the button on the small PCB.
Looks like there is a part missing, but there is no sign of it. Is it a spring which has taken off into the blue? Something is needed to spring back the red button so that it is firm and align it with the button on the PCB.
Please can anyone help me find whatever I need to make the red button useable? New, 2nd hand, picture of parts breakdown or anything to reveal the unknown.
Roger
rogndmeg@waitrose.com
  • 3,037 Answers
Your manufacturer will be able to provide the missing piece. Either it could be a spring or some rubber component. Your user manual should provide a number to call them at. Otherwise I will find one and post it here. Let me know if you need anything else.
Posted on Jul 20, 2008
    President:
  • 2,712 Answers
Looks like you just need the button replaced, mate..
  • Swilin Sampson
    Swilin Sampson Jul 20, 2008
    Any repair shop will be able to do that for you..
  • Swilin Sampson
    No point us going about the finer details of replacing the button..you need the services of a repair man..
    Scholar:
  • 191 Answers
Either the part has a missing pcb lock or its broken. Get it replaced from the vendor if it it under warranty.
  • Moses Clive
    Moses Clive Jul 20, 2008
    Or else you can take the part out and get the same switch from any local store and get it replaced
  • 6,487 Answers
You just need to take it to a repair center near you so they can replace the button or the missing piece on it..
Good luck........
Mitox 250-c strimmer pull cord
The starter pulley looks fine, however the small starter pawl and spring is missing rom the starter cup on the crank, it should be retained with a c clip from behind the cup
May 01, 2013 | Garden
Our hitachi has horizontal lines across the screen first it was just a small area now it half of the screen what could be causing this?
I have a suggestion that will tell you and me exactly what your problem is--Does set have small button on front that says MAGIC FOCUS? If it does press it and after it starts press it again--it will stop the magic focus and bring up the convergence grid on the screen----you will see a grid of lines and just need to look at them----if red or blue is out of place you have a convergence problem--very common on this kind of set.
If set does not have MAGIC FOCUS BUTTON (IT IS ON THE RIGHT OF THE KEYBOARD AND MAY BE RECESSED) You can remove the front speaker grill and the inspection plate behind it----there is a tiny small push button switch on the left front of the circuit boards--it will have blue button--us something not metal (I use a eraser end of a pencil) this will engage the set into the same convergence mode.
You just need to see what the grid looks like--if it is skewed etc--YOU KNOW YOU HAVE A CONVERGENCE PROBLEM.
If it is a convergence problem I CAN TELL YOU WHAT IS INVOLVED TO REPAIR THE SET---it will depend if you can do it yourself or need to have someone do it for you--most of this repair is just getting at a few parts and being able to do good soldering etc.
Try to check to see if you actually have a Convergence trouble or something else--if the lines on the grid are not white--red or blue bowed or out of place anywhere--it is convergence problem.
Seeing is believing and if you see the grid looks bad.
let me know--I am here to help people---I HAVE FIXED HUNDREDS OF HITACHI SETS WITH ALL KINDS OF TROUBLES--CONVERGENCE IS THE MOST COMMON PROBLEM--BY THE WAY: CONFIRM THAT ACTUAL MODEL NUMBER IS 51F500.
regards, SD TECH
Oct 15, 2009 | Hitachi 51F500 51" Rear Projection...
Transmission trouble. fluid looks fine. absolute
It sounds like you might have blown an axle. Especially if there has never been any transmission problems before. You said the fluid looks fine, and by that I take it to mean the fluid is clean and red, and its full. A blown axle will make the click noise, as the splines on the end of the axle are trying to mesh with the splines inside the transmission. The problem could be in the trans., but I'd pull the axles out first and check them, as axles are a lot cheaper and easier to change than a transmission.
Aug 01, 2009 | 2001 Ford Focus
Red rings of death on my xbox 360 I need to know how to fix it
the red rings can be caused by any number of things from a faulty power pack on the suppply cord to a loose av cable from back of x box. but the main cause of the "Red Ring of Death" is overheating. On the main pcb inside the xbox, you will see 1 or 2 small micoprocessors,
depending on when u bought ur box and what version it is,
when the unit heats up the pcb bends causing the processors to lift off the board and loose contact, you can either try mounting the pcb at diff points so it doesnt bend, or the longer term fix is apply some extra heat sink compound between the processor and the pcb and re solder the processor to the pcb. anyway. good luck.
Jul 05, 2009 | Microsoft Video Game Consoles & Games
My matsui mf2w/a dishwasher sticks during cycle. normally about 10 minutes into the wash. i can move it on manually but the wash is poor. the water does not appear to be heating
check the safety thermostat which is located at the bottom of the dishwasher. you have to remove the bottom plate,and then you will find easily the thermostat-KSD201/PF 90. you have to reset this probably.there is a red wax dot in the middle this thermostat, so remove it and use a needle to press a very small button inside. the heating element is working well probably.you can measure resistance on it to be sure.
Dec 02, 2008 | Dishwashers
I posted a link for a free manual on your first thread.
Here is the link to the thread
http://www.fixya.com/support/t810551-matsui_lm20n2_off_button
Here is the manual
http://www.partmaster.co.uk/cgi-bin/downloads.pl?brand=Instruction+Manuals&criteria=lm20n2
Let me know if you are unable to see my post there so I can notify Fixya Admins about it, thanks
Jul 22, 2008 | Televison & Video
Matsui Lm20N2 on-off button
I need the model number to get the manual, please provide it so I can see if it is available
Jul 20, 2008 | Televison & Video
Problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
Jan 04, 2008 | Nu Mark AXIS 9
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Televison & Video Logo
535 people viewed this question
Top Televison & Video Experts
