Question about Haier Energy Star ESA3183 Air Conditioner
Not cooling ESA3183 FRIEDRICH hi my question is that the unit does not work very well the filter freezes to the front of the unit even on a low setting how can i correct this ? any info .....will be thank full. thank you
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This only means low on freon or low air flow across the indoor coils , the unit probably needs a full cleanning and service!
Posted on Sep 07, 2008
Hi, I have a Friedrich air conditioner. Old one I am pretty sure. Maybe 9 years. Model is SL28J30A-D. I have a feeling my filter is not working properly or I don't even have the right one in. Currently I...
The evaporator coil (cold coil) would freeze up if the air entering is restricted. It could shut down because the rear coil (condenser coil) is dirty or obstructed. Sometimes there's debris or even bird's nest blocking the condenser air outlet, this causes heat and high head pressure.
Aug 27, 2013 | Friedrich Heating & Cooling
We have a friedrich model sl36l30a-e the compressor keeps freezing
First, be sure the air intake filter is clean and not clogged. If that checks out OK, and you can access the cooling coils, clean them with a sponge or rag, dipped in warm water mixed with a mild dish washing liquid. Rinse them with a clean wet rag and dry them. Then put a light film of WD40 on them. Also, clean the cooling fins on the rear of the unit using a soft bristle brush.
If all of the above did not solve the freezing problem, the compressor may need to be recharged with refrigerant gas. Which, is best left up to the pros.
I hope ths has helped you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Friedrich Heating & Cooling
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
Coil freezes up even on low cool..room does not get cool
dirty coils or low freon: clean coils off and out, they sell coil cleaner in a spray can, as far as needing charged, you will have to find a licensed a/c repairman, but honestly if it comes to calling someone, it is cheaper to buy a new one, Hope this helped Tim
May 30, 2011 | Friedrich QuietMaster SL28J30A Air...
Unit freezes up and then won't run on the cool settings only fan until if defrosts. Unit bottom fills with water after defrost.
Most common reason for unit freezing up is lack of air across the evaporator coil (where cold air comes from), usually because the filter and or coil is dirty. Check the filter - wash if it needs it and make sure coil is clean. Brush with a brush or use fingers to remove matted dirt/hair.
A less likely reason is 'low on refrigerant,' and unless you know how to install a service valve and charge an air conditioner (along with finding the leak) you will need to call a Service Tech.
hope this helps
Jun 19, 2010 | Friedrich QuietMaster® KS12L10...
The unit freezes up
When a AC freezes up the most likely reason is that the evaporator coil (the one the cold air comes from) is 'dirty,' and/or the filter (that goes in front of the coil) is also 'dirty.'
Be sure to defrost the unit (if it isn't already).
If it presently has ice on it - just turn the unit to FAN ONLY and allow it to completely defrost (all ice gone).
Then: Be sure the filter is 'clean' and air can flow through it.
Be sure the coil is also clean.
Note: if the coil is dirty you can usually clean it fairly easy with a brush. Often (especially if the unit is freezing up) you can actually 'peel' a layer of 'wet matted stuff' from the coil by hand.
Another reason (less likely one) for the unit freezing up - is that the fan motor is going off (when it shouldn't) and the "lack of any air" over the coil is causing the unit to freeze up. You didn't say anything about the fan motor not running so it's not likely this is your problem - but be aware - that fan motors can get hot and will go off on internal overload - UNTIL - it cools down and then will come back on - so - if you're not watching - it's possible the motor could be "heating up and going off (for 30-90 minutes) and coming back on" without you realizing it, which would cause the unit to freeze up. Like I said - this is not likely though. If, however, it is doing something like this - the 'sure-cure' is to replace the motor. The cost to replace a blower motor will be somewhere in the neighborhood of $200 which should cause one to think about buying a new unit.
Another reason - also 'less likely,' is that the AC is 'low on refrigerant.'
If - after checking the filter/coil - you find that they are both clean and not causing the problem - and you've watched the fan motor and it's not going 'off and on,' then, you must consider that the unit is 'low on refrigerant,' which will require a Service Tech - who has the expertise and tools to repair the leak and re-charge it. If this is the problem you're probably looking at a repair bill of $75 -$125 - which when considering the price of 'new air conditioners' might cause you to think about buying a new one.
Hope this helps.
Jun 10, 2010 | Friedrich CP12C10 Wall/Window Air...
My unit freezes up after being on for few hours. please advise. thanx
make sure your air Filter is clean your Evaporator being Dirty will cause freeze ups also
after changing filter and unit is completely defrosted turn on indoor fan only and check airflow coming out of register if you do not feel much air coming most likely your coil is very dirty if Both Air Filter and Coil are Clean could be Low on charge those are the most common causes of freeze ups
Jul 01, 2009 | Friedrich WallMaster WS12A10D Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Aug 28, 2007 | Friedrich M18CF Split System Air...
Haier Energy Star ESA3183 Air Conditioner Logo
48 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
