I had to replace the bulb in my 4650 now my convergence is off. any solutions ??
Thanks
SOURCE: slight RGB alignment problem
This picture can probably show you better than I can describe it;
http://img114.imageshack.us/img114/8957/spa0108pi0.jpg
We had the same problem, and it seemed to fix itself when we did the following (not sure exactly what it was we did, but it worked):
1) Remove the outer box on the right side (one by the lens), rear, and top. (you'll need a T9 torx screw driver with a long shaft as the first 4 screws are on the bottom under the rubber feet and caps on the front corners of the bottom.)
2) On the top is a board that has 3 orange cables coming out of it as well as some others. We completely removed that board and reinstalled it.
3) We determined that the 3 orange cords control the color out put.
4) So leaving all of the outer sides off, when we reconnected the board and provided power, the image came out properly aligned.
5) We're now struggling w/color. Based on how you insert the orange cords you get different color saturation. We seem to be missing a proper/consistent red display.
6) But the colors are all aligned and the image clear. We're getting there . . . .
Be very careful!!! You could electrocute yourself.
AFTER CHANGE THE BULB THE CONVERGENCE OFF, NO ACESS IN MENU, SHOW BUT NOT ENTER.
