Question about RCA D52W19 52" Rear Projection Television
Tv will not come on
Tv attempts to come on 3 times bt will not. Then it takes 1 min. to try again and it still will not come on.
  • RCA Master
  • 5,138 Answers
You have 3 capacitors that need to be replaced.
Posted on Jul 26, 2008
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
2007 dodge ram 1500 5.7 won't start. Key turns but won't start the truck. The security system is preventing it from starting. How do you reset the key?
Hello there and welcome to fixya
Normally you WILL HAVE THE RESET PROCEDURES IN THE OWNERS MANUAL BUT IF NOT PLEASE TRY THIS pull the positive battery off the post and leave it off for 10 min then reattach it AND ATTEMPT TO START THE VEHICAL IF IT STARTS GREAT HOWEVER IF NOT TRY THIS
turn the key to on DO NOT START THOUGH LEAVE IT THERE FOR 3 MIN THEN TURN THE KEY TO OFF FOR 30 SEC THEN BACK TO THE ON FOR 3 MIN AGAIN THEN REPEAT THIS STEP 1 MORE TIME THEN LEAVE SIT FOR 1 MIN THEN ATTEMPT TO START THE VEHICAL
Dec 24, 2011 | Dodge Ram Cars & Trucks
When i turn on the TV...it runs for 5-10 min...then shuts off... this turn it back on...it runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Changed ignition switch and now the car thinks it's being stolen. It shuts off the gas flow. Does anyone have the code or know how to reprogram for the new switch?
YOU HAVE A PASSLOCK SYSTEM WHEN YOU TURN THE KEY THE COMPTER READS IT OK OK RESET YOU MUST DO THIS
1 TRY TO START VEH AND LEAVE IN RUN POSITION FOR 10 MINS
2 DO IT AGAIN
3 DO IT AGAIN
FOR A TOTAL OF 30 MINS THIS DOESNT ALWAYS TAKE THE FIRST TIME. MAY HAVE TO DO IT MORE THEN ONCE AGAIN TRY TO START VEH AND JUST LET THE KEY GO AND WAIT 10 MIN 3 TIMES
Feb 11, 2010 | 2003 Oldsmobile Alero
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Sony kdl-46xbr4, horizontal lines
Sony is replacing LCD Panels at no charge until October 31 2012. The KDL46XBR4 and KDL46XBR5. If you paid to repair they'll pay you the cash back you paid to repair it.
Jun 11, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Line on screen after about 10 mins
it sounds like you have a component on your TVs circuit board going out, like a capacitor. as the TV warms up, it gets worse.You basically have 3 choices:
1) Take it to a repair shop and get the part replaced.
!!!!WARNING!!!! DO NOT ATTEMPT TO OPEN YOUR TV! ONLY A TRAINED TECHNICIAN SHOULD! THERE IS ABOUT 150,000 VOLTS IN THERE, YOU CAN BE HURT/ KILLED! !!!!WARNING!!!!
2) Live with it, until the part fails totally, at which time #1 or #3 will apply.
3)Replace the TV with a newer one.
I Hope that this helps you in your quest for answers.
Apr 19, 2009 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
