I'll assume you used the remote here (like most of us do) to arm the alarm. Try turning the key in the door lock - turn it to lock the car (which arms the alarm), and then unlock it (which should disarm it). Do this a couple of times if need be, and it should disarm and allow you to start the car.
Push the lock button on your key fob for three seconds, until the lights on your dashboard blink. Your key has been reprogrammed, and your alarm and computer have been reset. Turn your Kia off, remove the jumper wires and close the hood.
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
This is the problem due to your anti theft alarm system. You have not mentioned which brand of anti-theft alarm system you have? Anyhow, most of the systems have a reset switch inside the kit, open the kit and on the main board, u will find the reset button, press that and hold for 5 sec, the system will be reset. Otherwise, there are 2 or 3 fuses with the wiring of kit, remove those fuses and ur engine will wake up but the anti-theft system wont work then, hope this will solve the problem
fuel pump could be dead or maybee u need to re program youre car keys some times the program in the key looses the program or doesent send the signal to the key swith .
