Question about HP vs19 (Silver) 19" LCD Monitor
Hp monitor vs 19v
Would you be willing to try to fix mine? We tried but it still doesn't work! I really could use the help!
thanks
I think I have the same problem as above. Sometimes the blue light will light and then go out.
I looked for screws to hold the screen together, but, I think I will have to try the pry thing next.
My monitor is still under warrantee, and after communicating with HP support, their final response is to buy a new one from them, not from a store. The closest HP affiliate is 50 miles away and they insist I bring my PC in also, as they don't believe my problem. They think it is my PC. What good is a warrantee from HP? I will fix it myself. Maybe HP will pay me. HA!
Posted on Aug 17, 2008
  • bill4w Aug 23, 2008
    After many emails back and forth from HP, I finally found the email addresses for the CEO/Chairman of HP and the Board of Directors.
    I emailed both and I will be receiving a NEW replacement monitor in several days. My problem with the warrantee went to the TOP.
For those with HP vs19 monitors. I had the same problem of the monitor ceasing to work after less than 2 years. In desperation before trashing it, I did some research on forums and found someone who boldly tried to fix it himself since it was dead anyway. I sent my monitor and this person's solution to a friend who is a repair man and the info was right on the money.
It appears that HP is using capacitors that burn out too fast. There are 3 capacitors on the board inside the monitor that were oozing brown gunky stuff. When he replaced the capacitors the monitor worked fine. My repair guy opened my monitor (which took a bit of prying gently all the way around several times as it just snaps on) and found the same goopy capacitors in mine. He replaced the 10v ones with 35v ones and the monitor now works fine. The total cost to me for the 3 capacitors at Radio Shack and his labor was $30. I am so glad I didn't give up and just trash the monitor. Hope this helps. I would not attempt to fix this myself but by taking it to someone you know that fixes computers and asking specifically for them to check that problem might save you lots of big bucks....
How to fix
tried to hooked up with other monitor just to ensure if the cause is your pc. if the monitor doesn't receive signal it will goes to stand by mode.
Sep 07, 2012 | HP W2207H 22-inch Widescreen LCD Monitor
Dual monitor vs Large monitor?
Or go through this page and see.
Whether it's helpful to you or not?All the Best!
Thanks for using FixYa.
Apr 26, 2012 | Dell Optiplex GX520 (GX520 2.8) PC Desktop
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
No sound from built in speakers HP VS 17. Device is working properly when i checked the device manager and i can see the speaker icon in the taskbard. was working before i shifted the desktop to a new...
Try using MP3 player feeding the monitor to see if you get the sound OK first. Are you using stereo male to male mini jack for connection from PC audio line out (Green jack) to Monitor audio line in (Green jack)?
Feb 27, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Blurry screen
check your cable VGA or DVI - reboot - if not work, uninstall your drivers and reinstall them
Sep 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
Monitor works for a fraction of a second
See article written by sillybit (me) for the Westinghouse 19v5. My 20v5 had bad caps in the power supply - it did the exact same thing as yours. $8 worth of parts from radioshack and an hour or two is all mine needed.
Aug 01, 2008 | Westinghouse LCM-19v5 Monitor
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP vs 19 Flat Panel LCD Monitor will not turn on.
Find instructions to fix a problem like this here:
http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
It's helped a lot of people so far, hopefully it will help you too.
Oct 11, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
