Question about HP OfficeJet 7310 All-In-One InkJet Printer
Carriage Jam I'm receiving "cariage jam" on the printer screen, however there isn't anything obstructing the carriage pathway. I've done the Carriage alignment, however that failed. I suspect it could be a sensor prob. how could I confirm that this is the problem & how would I repair it?
  • 4 more comments
  • chas0926 Jul 21, 2008
    Thanks for your assistance. I followed the directions to the end & it appeared to remidy the problem, at 1st, however the carriage error is appearing again & the printing stops midway. I'm wondering if the contacts need to be cleaned & oiled? Would there be an instructional diagram available?
  • tylerlueker Aug 10, 2008
    well my name is tyler i have the same problem how do i fix it my e-mail address is tylerlueker@live.com please help
  • lmc549 Oct 24, 2008
    I get the carriage jam Error message and then the alignment cancels. I just replaced the ink cartridges, but this was happening once before and seemed to fix itself. Now it doesn't work at all. Please help me. Thank you.
    lmc549@cox.net
  • tjinaz Nov 04, 2008
    Yes, I am getting the carriage jam message along with a loud grinding noise. Followed instructions, which were very helpful. While I found no malfunction in the carriage chutes, there was a huge (and I mean HUGE) ***** of ink that had apparently been accumulating from some time under the cartridges. I scraped up the ink which had formed into small peaks, cleaned all contacts and gears with alcohol. Did alighnment and cleaning of print cartridges/heads. Printing still out of alignment (although slightly better than it was), and grinding noise is still present. Guess I buy a new printer :(
  • rich Dec 02, 2008
    I have a problem with my printer the HP 7310. I have a brown belt that is dislodged, which gives me a carriage jam error. Does anyone know how to resolve this problem. And as for HP, of course they want me to bring it in for repair. Thanks Richy
  • Anonymous May 05, 2009
    i put a new carriage in my printer, when i shut the door it say the carriage is jam however there isn't anything obstructing the carriage pathway. Ive check it a million time & the only thing i can see that it's doing is the bottom of the carriage is scrapping alone the bottom as it run across.
I tried all these steps and it still did not work was ready to throw the printer out from frustration. Instead I traced what I did when I had the jam. I believe if the factory can fix it so can I. My printer is now working and it was so simple yet HP does not tell you how to fix it.
Posted on Jul 27, 2008
    Scholar:
  • 87 Answers
Here are some common problems with this series of machine HP Officejet 7210, 7310, and 7410
1-the biggest problem is the carriage breaking. Carriage breaking is common to all machines that use the 96 and 97 cartridges. There is a metal piece that resides in each cartridge holder. This piece fits in to the right side of each slot and is ultimately held in place by a small piece of plastic. This plastic piece breaks and allows the metal piece to shift. You will notice that the metal piece is pointed on one end. When the plastic piece gives way this pointed end will poke a whole in the flex cable on the cartridge carriage. Resulting error is cartridge not recognized. You may not even recognize the metal piece being lose until its too late. If you do recognize it...then if you are careful when inserting your cartridge the machine will still work fine. We will do this repair replacing the carriage for $100..this includes complete disassembly and cleaning of machine. Just ship it too us.l
2-with heavy use of this machine, ink spray and ink tend to build up in machine. Most machines we see this in starts with page counts over 10000. The ink spray begins to cover sensors, encoder strip, encoder wheel and things that monitor paper movement and cartridge carriage movement causing a wide variety of problems. Crappy print (usually looks like printe jumps around) after installing new cartridges is usually a result of heavy ink mist/spray covering the clear strip (encoder strip) that runs behind cartridge carriage. You can try cleaning it with a wet tissue. Just be careful and don't pull on it too hard. This is just one example. Usually complete disassembly and cleaning cures 95% of what ails these machines. We charge $55 to clean these units.
Inkworks
866-381-0541
Posted on Nov 06, 2008
Further to my first solution to this problem, I incorrectly said that I moved the carriage to the right. I meant to say the left. Please try this. Regards - alanforfaxes
Posted on Oct 16, 2008
    Problem Solver:
  • 4 Answers
I don't know if you have solved this problem, but I had the same recently. I deduced that the carrige had become out of sync following a paper jam. I cure my problem by turning off the machine, moving the carriage (gently) to the far right side of the machine and then switching on. The carriage went to its home position and since then has worked fine. Hope this helps. - regards alanforfaxes
    Novelist:
  • 106 Answers
below is the document that u want you to follow inorder to resolve the issue..
CLICK HERE ===>> DOCUMENT
After following the steps, please let me know the result.
thank you so much.
adonscott
Posted on Jul 21, 2008
  • Guardson Nunez
    Guardson Nunez Jul 24, 2008
    hi,
    The issue still not resolve, try to check the warranty status of your printer then call HP at 1-800-474-6836. If the technician of HP found out that the printer still in warranty and it has a hardware issue, they can go ahead an have it replace.
    Thank you so much.
    adonscott
Hp officejet 4630 carriage jam
Check first:
Are you printing correctly? Are the papers in their correct position? Look the picture below, is it 100% identical to how your printer looks right now?
hp-officejet-4630-carriage-jam-g3kwcv4s0uxqjd0jsmqlsidv-5-0.png There are a few ways:
1. Open the cartridge access door and remove any obstruction in the movement of the cartridges.
2. Re-install cartridges.
3. Plug the printer electric source directly into the wall outlet.
4. Check the picture above and check your alignments again.
Jul 11, 2015 | HP Officejet 4630 e-All-in-One Printer
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
Carriage jam when there isn't one
the carriage is not the CARTRIDGE ,
the carriage(the cartridge holder) stall at somewhere in the print area
i hope my answer is useful?
Dec 11, 2012 | HP OfficeJet 6210 All-In-One InkJet...
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Carriage jam
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Carriage Jam
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 17, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Jan 23, 2008 | HP PSC 1610v All-in-One Printer
Hp psc 750 cariage problem
Hmm...
Look inside the printer for anything that shouldn't be in there... like paper or dust.
Cariage jam is shown whenever the carriage is blocked by something... even the service station (the black container in the right where the cariage sleeps). With the printer cover open try to power up the unit. Look where the cariage stops. Ceck with a flashlight for any obstacles in that area. Olso verify if the service station is moving. It could be broken and the cariage cannot move away from it.
Jan 02, 2008 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
758 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
