Question about HP vs19 (Silver) 19" LCD Monitor
Hp monitor vs19d
Are you still willing to fix them? I have one that we tried to fix without success and I all the caps were blown like you described. I just think we were inept. Care to give it a try?
I would appreciate it!
Thanks!
JJ,
If you want to give it to me, yes. if you want me to fix it and give it back to you, i'm not interested. But honestly, just give it another shot. make sure you are careful w/ your solder.
Hovik
Posted on Jul 20, 2008
VS17 Monitor - power light only blinks, but monitor screen stays dark.
Look for bad caps in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Also read here: http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
Aug 30, 2010 | HP Computers & Internet
Vs19d monitor has power but screen is not coming on
You will need to open it and inspect the capacitors in the power supply first, hopefully it does not have bad lamps assembly like the one in my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Post back what you see inside so we can guide you further.
Apr 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Will not turn on, There is power to the unit, it is like the switch doesn't work.
There can be various reasons and different troubleshooting steps in a case when the monitor will not turn on:
Try tehsteps as guided below to ascertain and fix the issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3955457&prodTypeId=382087&objectID=c01295035
Also if there is a capacitor problem which does not let the power supply work properly please try the below link:
Mar 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
My hp vs19d power button blinks on and off slowly. what does it mean? if i let the computer sit for say 3 hours the monitor will stay blank. even after moving the mouse to wake things up
the monitor is in sleep mode ... have you tried hitting the keyboard Space bar?
if you disconnect the video cable from the pc does it display ( video disconnected) ? if it does it then is probably the sleep issue
Oct 06, 2009 | Computers & Internet
My moniter wentr out.
Hmm, haven't had experience with this exact monitor, but several people have had success with my tutorial on fixing the vs19d and vs19e. Check out the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP VS15c No power
Yeah replace the capicitors should fix it - worked for me.
Aug 24, 2009 | HP vs15 15"LCD Flat Panel Monitor
Monitor just quits,
you posted to a wrong place, to an empty stop, its not a response post at all. but....
old old VS19 , with CCFL inside, (oops)
the OSD is dead, proving the monitor is dead.
the CCFL laps are bad or the board is a bad.
not all boards (PCB) fail for caps, unless,made in the bad china cap era....
i buy my caps at Mouser ,x10 better quality btw.
there is more to this board than just a cap
photo is of early L1503.
best place to look is get a used board from Ebay.
HP does not sell this board now, its LEGACY.
nor do they sell or offer schematics (lacking that very hard to fix)
those 2 black rectangles below are the CCFL high voltage generators. ether can fail. and CCFL is dead.
use a flash light to the screen yet , while pushing the Menu key there
for the OSD display to show up???? if it does then the CCFL parts
are bad. dead backlight.
Aug 04, 2017 | HP vs19 19" LCD Monitor
My HP vs 19 desktop monitor is on, but the screen is blank. It flashes on for less than a second when I turn the monitor off, and then back on -- but then goes blank. What is the solution?
If you are handy at fixing things.
Here is a link of how to fix your monitor. I had the same problem, and found this link, followed the instructions and it cost me $5.13
to fix my HP vs19 LCD monitor, and its still working great.
HP vs19 LCD Monitor fix
Don't drag out your soldering gun these are too high wattage and will melt the board. Use a 40 to 25 watt soldering iron.
Dec 13, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP vs 19 Flat Panel LCD Monitor will not turn on.
Find instructions to fix a problem like this here:
It's helped a lot of people so far, hopefully it will help you too.
Oct 11, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
