Question about Toshiba Computers & Internet
Power cord adapter falls out of socket in rear of laptop for satellite P105-9722 is there a cure or should i buy a new power cord and adapter?
Here is a solution to this problem
http://cgi.ebay.com/Tether-Mate-Power-Cord-Laptop-Guitar-Electronic-Cord-/130515693027?pt=Guitar_Accessories&hash=item1e63576de3
Posted on May 02, 2011
  • 80 Answers
Hi im wesley. please make sure the socket is not maybe broken, if its fine then i would suggest replacing the adapter only because the power cord shuold be fine.
Posted on Jul 21, 2008
Dead Board or Battery? My "new to me" Toshiba Satellite M55 worked for about 30 minutes w/out external power. When it told me to plug it in; I did. It gave about three more warnings to plug in; then d
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 09, 2013 | Toshiba Satellite Laptop / Intel Core i3...
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Toshiba satellite c660 motherboard not power
Sep 04, 2012 | Toshiba satellite c660
Toshiba satellite a215 loses connection with power cord
The fault could be the adapter plug (a broken wire at the plug) that connects into the laptop or a faulty power socket on the laptop. In most cases it is the power socket on the laptop, it could be just a dry solder joint in the circuit board where the power socket is soldered on the motherboard or the power socket is faulty and therefore needs to be replaced.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Mar 06, 2010 | Toshiba Satellite A215-S4747 Notebook
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
Charger blinking not charging, my orginal charger stopped working due to a damaged cord, I bought a replacement and all it does is blink on my computer while supposedly charging, after 4 hours, it is still...
Dec 09, 2009 | Toshiba Satellite A305D-S6848 Notebook
I have aN HP dv6700 pavillon. I been trying to pulg the wire cord but the blue light doesnt turn up. I called to hp and they told e only for look it its 300 . I bought this computer one year ago
HP has shipped some bad notebooks and has what they call "Enhanced Warranty Program" if your laptop falls into this category you may qualify for a free repair from HP.
Please see the following link and read all information carefully to see if you qualify for this warranty:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jun 23, 2009 | HP Pavilion dv9000z Notebook
Toshiba laptop satellite A135 S4527 power
take it with you when you go and try the new cord before you buy it , Toshiba's are Notorious for the charger cords to be crappy and also the port for the laptop itself to break and need repairing , witch you have to send it to toshiba to get done if that is the case
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
Power cord
Yes you can check in IT stores (Radio Shack, Best Buy etc) Sometimes it comes as universal adaptor. All you need is the match socket type Voltage and Amperage. There are available for car also. You can check the brand names Targus, Belkin and other trusted brands.
Good Luck
Jan 24, 2008 | Durabrand DUR-1500 Portable DVD Player
Computers & Internet Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
