Question about HP Compaq nc6220 Notebook
Touch pad driver.
The touch pad on the compaq nc6220 has frozen and will not resume operation, currently a usb plug in mouse works, but i would like the touch pad back, do i just re-install the touch pad driver? and if so how?
  • kaylachan Jul 21, 2008
    Thank You.
    Genius:
  • 2,028 Answers
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Posted on Jul 20, 2008
  • Ryan Rogers
    Ryan Rogers Jul 22, 2008
    You're welcome. Please rate this accordingly. Thanks.
    Pyrhyc
    New Friend:
Hello.pls you help me.i have my laptop compaq 615 the prblims is hang up and also very slow and touch mouse is not working that all.thank you very much.
Posted on Feb 11, 2014
My. Compaq touch pad and buttons stopped working. Running win 7
ok, do you run 2 mice?
USB mouse,? or wireless mouse if yes that is the problem ,, is yes say so , we fix that. or remove that.
I cant see you PC so i must beg for facts.
did pc come with Windows, 7?
no PC stated. so..>????
to make the touch pad work, go to hp.com
go to your pc, unstated\
go to the OS , w7 for that PC,
and load the touch pad driver
if HP does no support your PC on W7 then that is a big problem
they can help you can they.?
so then we get more complex, we must find out exactly what touch pad you have ,then go to that maker and get a driver
is PC on the internet now.
yes.
then go to device manager,
click the touchpad listing and remove it or click update this driver.
if lucky W7 finds the driver best and replaces it.
and it now works, this is called Plug and PRAY.
May 28, 2017 | Compaq Computers & Internet
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ??...
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Mar 24, 2011 | Compaq Computers & Internet
My pointer is frozen on my emachines laptop? I've tried restarting it but that didn't help.
I hope your touch pad or touch pad driver is not working - try to reload the driver and see if the problem persist its your touch pad - then connect a usb mouse externally and see its working
Jan 20, 2010 | Acer Computers & Internet
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
My laptop touchpad stopped working
this is probably a driver issue if you are lucky other wise the touch pad must have become faulty
if its a driver issue go to this site
http://www.synaptics.com/support/drivers
and download the drivers according to your operating system
install them and check if the touch pad starts working
if not then its probably a physical fault and needs replacing
Sep 29, 2009 | HP Compaq Presario CQ50-110US Laptop
Touch pad not working in HP laptop
Try checking if it has been disabled.
Select Start > Control Panel > Printers and Other Hardware > Mouse
Please don't forget to rate this solution.
Jun 12, 2009 | HP Compaq nc6220 Notebook
Frozen touch mouse
Get your laptop utility CD/driver. Borrow a USB mouse and then you access the laptop driver so you can reinstall the touch pad. That should work (it worked for me).
Then before ejecting your utility disc/driver, you copy the touch pad folder and then paste it to your desktop so the next time you'll need to reinstall your touch pad, you can readily access it.
May 27, 2009 | Dell U0636 Mouse
Frozen mouse with a touch pad laptop computer
file:///C:/Documents%20and%20Settings/GX-620/Desktop/TouchPad_ALPS_v.7.0.1101.14_Vistax86.zip
reinstall your touchpad drivers, and make sure it is not switched off (if you were using an extra mouse)
May 13, 2009 | Acer Aspire 5315 Notebook
Dell inspiron I6400 touch pad is not working
Unless there is not a hardware switch and the only manufacturer that I know of that did that was Compaq/HP about 5 or so years ago. Typically there are no drivers to be installed for a mouse (touch pad) as a generic set is in the driver library of the operating system. 9 times out of 10 it is a hardware failure. With that being said, if it has warranty send it in, if it does not, (although it may just be a loose connection or the touch pad itself) most repair shops are going to run anywhere from 150 - 300 dollars just to crack it open. Best option is to get a small USB mouse, unless you just really want the touch pad.
Nov 17, 2008 | Dell Inspiron 6400 Notebook
HP Compaq nc6220 Notebook Logo
589 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
