Question about AEG Dryers
Heater not functioning drum rotates but no heat on either setting
  • 770 Answers
Need model number and brand
Posted on Jul 20, 2008
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
It doesn't heat up and it's not the breaker.
may be heater coil, located inside machine on back right side. unplug dryer, open dryer door and remove screws, with a flat tip screw drive gently pry on each top corner till it pops off, gently move panel forward and disconnect door switch. sit panel aside, lift top all the way up it is clipped on the back so it will not fall off. look to the back and right and the coil looks like a spring, it is easy to change, all you need to do is will the make and model call a appliance store and they can tell the price for a new one. good luck tim
Sep 18, 2010 | GE DBXR463EBWW Electric Dryer
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
Apr 20, 2010 | GE DVLR223 Dryers
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Open Questions:
Dryers Logo
60 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an AEG Dryer Expert? Answer questions, earn points and help others
