Question about Goodman CLQ36AR49 Air Conditioner
Fuse blown up
I have a goodman split air conditioner. Every year I noticed that the fuse in the condenser is blown up often and everytime I called up a technician they will replace the contactor. Last year they repalce it with Siemens Contactor.
If I want to replace it what is the best brand and what causes the fuse blown up.
    Champion:
  • 254 Answers
Siemens, G.E. C/H, Square D most of these contactors are about the same.
Most likley there are two things which will cause a fuse to blow.
1. Is a direct short from line to ground.
2. High Amperage draw
I would check the amp draw while it is running on a hot day and match it with the rating on the tag.
Hope this helps you
please rate me
Posted on Jul 24, 2008
DO I NEED TO REPLACE THE FUSE TO THE CONDENSER OUTSIDE IN THE BOX?
If it's not working, you can check the fuse. If the fuse is blown, you need to check the system. Simply replacing a blown fuse will likely just blow the new fuse.
Jun 12, 2015 | Sanyo Split System Air Conditioner
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 04, 2011 | Goodman CKL42AR42 Air Conditioner
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
DEDICATED CIRCUIT BREAKING IS TRIPPING OFF...POSSIBLE CAUSES ARE?
May be compressor struck/Condenser fan motor struck/ short circuit/loose contacts are main reasons for fuse blown or breaker trip.
Dec 11, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Outside unit fan not turnnig
Could be a bad capacitor on the motor.Or a blown condenser fuse.
Aug 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Where is the fuse/breaker on a goodman cple 18-1
Hi, I wanted to look up the numbers you gave me as you listed 2 different model numbers, the CPLE-18-1 is a 1&1/2 remote condenser and the other you showed CPLE-24-1 is a 2 ton unit. Doesn't matter, but if your power was lost you have your main breaker box at your meter, and at the condenser you will have a disconnect box with a pull out type plug. If you see no fuses, try removing the plastic cover as they are required to install 2-fuses in side the box also. If this is a split system with the outdoor and indoor unit, you will also have a breaker inside for the indoor unit, its high voltage and you will have a circuit board in the indoor unit with a 3 to 5 amp auto type plug in fuse.
I hope this has helped you out on this. I will be here if you have more questions. Please do not forget to rate me as I know you will be kind. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contracted
Aug 08, 2010 | Goodman CPLE24-1 Air Conditioner
I just moved into a brand new home that has cental air (Goodman air conditoner) how do I turn on?
turn the thermostat to cool and turn the temperature down if it still doesn"t run check for double pole breakers that are off
Jun 30, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
115 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
