Question about Friedrich Heating & Cooling
White mist coming from in the wall air conditioner..
My air conditioner has been running for 3 days straight and Im noticing that a white mist is blowing from the vents..I have an in the wall air conditioner in an apartment.
  • 588 Answers
SOURCE: My air conditioner runs outside, but there is no
If your Indoor Coil is Froze Up, you need to shut the unit off and let it thaw out. After it thaws out for several hours, then turn the blower on at the thermostat, you’ll see a switch that says fan on/ auto
Move the switch to on and see if the blower runs if it does let it run another hour or so. Then shut it off and check your filter and indoor coil to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant. If the blower doesn’t run when you turn the switch to on then you need to check the blower out,
If your not familiar with any of this then you need to call a service tech.
Posted on Apr 27, 2009
  • 1033 Answers
SOURCE: The air conditioner is cooling,
Hello, Sounds like either the unit is not tilted properly or the drain is clogged. Does the unit have a drain hole on the bottum?
Posted on Jun 08, 2011
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
woobie dog
  • 1273 Answers
SOURCE: apartment central air vent
Hello.
It will usually be one of three things:
1. The vents are closed. Check that you can see up into the ducting. Usually there is a lever that opens and closes louvers behind the vent plate. If this is the case, you can open the louvers with the levers on the side of the vent plates to get your air. On older vents, the levers don't work very well, and may need replacement if this is the case. Not that you should, but I have opened the louvers with a screwdriver....It works....
-or-
2. A separated duct. Assuming that your ducts are overhead, the separation would be in the attic space.
-or-
3. An obstruction in the ducting. There may be a flapper that restricts air in one part of the ducting, forcing it more to the uther ducts. Sometimes these close off on their own accord and need to be reset for proper operation. An object in the ducting will cause the same problem.
I'd discuss this with your building maintenance team. The only item on this list that I'd take a crack at, if I were renting the apartment, is number 1. Even then, be very careful working on ladders. If you can see up into the vent, then there really isn't much else expected of you.
Hope this helps you. Regards, --W/D--
Posted on Jul 16, 2009
  • 69 Answers
SOURCE: Blowing water out the vents.
There is a water pipe from AC to outside,
if a lot of gel inside the pipe, it can make water flow become jam.
Clean it by blow the pipe with a compressor from outside.
Sometimes I did it with my mouth. LOL......
But its worked finally.
Posted on Sep 06, 2009
The right type of vent for a moble home
Some vents are adjustable where as you can turn them at the angle you want get those if you can,the vents dont have to be for mobile homes only. Take one of your older vents to an air conditioner parts store they should be able to match one for you.
Nov 13, 2013 | Heating & Cooling
Odorless smoke coming out of my amana air conditioner is the problem odorless smoke coming out of my air conditioner wath is the problem?
That's a cool mist, like a fog. It's not smoke and occurs when the outside humidity is extremely high.
Be sure the air intake filter is clean and if it continues for a long time, raise the temperature setting of the AC a couple of degrees and allow it to run, until the mist clears. It harmless, so don't worry about it.
Thanks for choosing FixYa.
Jul 30, 2011 | Heating & Cooling
I have a Duracaraft Humidifier DWM-250 series. It was working perfectly fine for 2 days. Then it stopped producing mist. I have cleaned the heating element, not used it for almost 24 hours just in case...
It may have a scale and mineral build up, prior to using bottled water.
To clean it, empty the tank of any water that's already in it and fill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the solution to sit in the tank for 30 minutes, before turning the humidifier ON. Once the unit is ON allow it to run for at least 30 minutes, then check to see it if it's misting, by holding your hand in front of the nozzle. If it is, allow it to run until the tank is 3/4's empty. Turn the unit OFF, unplug it and pour out the remaining solution. Then fill the tank with Bottled Distilled Water and run the unit for one hour. This will allow enough time, for the Distilled Water to flush the system. After that, fill it again with Bottled Distilled Water and use the humidifier as you normally do.
If it didn't start misting when you turned it ON. Allow the solution to set for 3 hours and then try it again.
Hopefully, this will solve your problem. It does 95% of the time. Please let me know if it worked for you. Thanks.
May 05, 2011 | Heating & Cooling
My 3-year old LG air-conditioner was leaking water. So i called some 'experts' to come fix it. This is the first time I called for maintenance service on the air conditioner. The 'experts' dismantled some...
White snow.. I had this issue when 2 inside unit electrical lines were hooked up backwards at the compressor. The compressor would pump too often and overcool the inside unit, because it was using the wrong temperature sensor. But you could have a different issue. I'd have them recheck your freon levels, that can cause it to cool too much - should be 120-135psi when it is running, after 5-10 minutes or so. They adjust this for the outside temperature though.
Oct 04, 2010 | LG LS-L1210CL Mini Split Air Conditioner
White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Jul 24, 2010 | Airtemp B3Q06F2A Air Conditioner
On the outa half of the wall, its spraying a very light mist, is that normal? Is it safe?
thats great you have it set properly in the window,thats your slinger fan keeping a mist on the compressor to help keep unit cool and head pressure down on unit,theres nothing dangerous its working the way it was designed
Jul 26, 2009 | Danby DAC12070EE Air Conditioner
Cloud of white stuff around my air conditioning unit
it could be a burnt out solenoid making a hole of its stem causing gas with oil to escape that is the white stuff
Jun 03, 2009 | Whirlwind FH-778 Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Frigidaire FAC125P1A6 when AC is on mist is coming out
Try cleaning the filters and running a couple of degrees warmer. If this does not work have the refrigerant levels checked by a professional.
Jul 06, 2008 | Frigidaire FAC124 wall/Window Air...
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Heating & Cooling Logo
872 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
