Hello &
Welcome to FixYa E-63 error
code in your Samsung Microwave is a T1 maximum timer error which means that the
power control board has gone bad and needs replacement. However, before replacing
it you can unplug the unit for 5-10 minutes to do a hard reset, if the problem
is back then replacing the PCB is recommended repair. Please get back to me if
you have any other questions. Kevin
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
