Sharp UX B700 Plain Paper Inkjet Fax Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have brought a tel/ fax machine from uk . after plugging in Frankfurt , I found that it does not work Please help
Branko Djurdjevic
Level 2:
Sniper:
  • Expert 103 Answers
  • Posted on Feb 03, 2011
Branko Djurdjevic
Expert
Level 2:
Sniper:
Answers
103
Questions
0
Helped
50974
Points
279
Maybe, in Great Britain they use 110V power supply, and in Germany you use 220V.
Check that
Silver sewing machine
Viscount was acquired by the Sliver Co.. I found this website where you can contact them directly. There is a link at the very top right..for Viscount/ Silver machines...
Silver Knitting machines Ltd
Units D & E Rectory Business Centre,
Rectory Road, Rushden,
Northants. NN10 0AG
TEL: 01933 311888
FAX: 01933 312888
EMAIL: [email protected] <~~ use this link to contact them
Our mission at Silver Viscount is to provide the best in the textile industry. We offer Sewing Machines and Overlockers, Knitting Machines and a complete range of Yarns and Accessories Click here to enter the Silver Viscount on-line Shop Company ProfileSilver Viscount was formed in 1990. Originally based in Mitcham, Surrey, the company moved to Bedford in 1999. In January 2001 continued expansion saw Silver Viscount move to new offices and warehouse facilities in Rushden, Northamptonshire.
Our extensive range of Silver Sewing Machines, Overlockers and Steam Presses are distributed throughout the UK and abroad. All have obtained an enviable reputation for both quality and reliability. Silver Viscount are distributors throughout the UK and Europe of Silver Reed Knitting Machines, the only major knitting machine manufacturer in the world today.
A huge stock of accessories and spare parts is available which together with our experienced after-sales service department provides support and back up for both the Silver and Silver Reed brands.
We also supply a variety of generic sewing and knitting machine parts, accessories, threads, needles and general haberdashery alongside our range of Forsell Yarns.
Northants. NN10 0AG
Tel: 01933 311888 Fax: 01933 312888
Email: [email protected]
Registered in England, Reg No.: 2558902 at address above
http://www.silversewing.co.uk/
Units D & E, Rectory Road Business Centre
Rectory Road
Rushden
Northamptonshire NN10 0AG Tel: 01933 311888
Fax:
[email protected]
www.silversewing.com
Rectory Road
Rushden
Fax:
[email protected]
Xerox copycentre C20 Can send a fax but not receive Help
Check if your telephone cable is connected at the " tel " plug on the fax machine
Brother intel 1279 fax. The phone rings but the fax does not com
Press the Mode button that has TEL/FAX , TEL , FAX. Press the button until the light beside the FAX mode is lit up. That is it! Should pick up on its own. Hope this worked for you!
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
On hook dialling
on hook is for dialing out some machine you push this button and dial the number to fax out.
there should be a off hook or stop button to release it
Bother intellifax 3800 don't no about it
These is a manual on line. Go to the official Brother website and it will direct you to it. I forget the exact link, but if you go to the site and can read you will be able to get the manual. It's over a hundred pages long so I didn"t print it out, but I did find it so I know its there. If that doesn't work for you smash you fist into the front of the machine, or even your head.
How to connect canon L295
Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
2answers
Panasonic KX-FPG371
Can you fax out? if not, look at the ports where the tel cord comes in from the wall. There are probably 2 ports. One labeled "line" or "wall" and the other labeled "tel" or "acc". MAKE SURE the cord in plugged into the "line" or "wall" port. If it is plugged into the other, you will still get a dialtone, but you will not be connected to the faxes modem. Hope that's all it was. If not let me know Ed
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
