Question about Maytag M7DH45B2A Dehumidifier
Leaking all over floor
My dehumidifier is collecting water and still leading all over the floor. there is no crack in the pan either
  • 3 more comments
  • Anonymous Aug 10, 2008
    Same problem, no answer. Where are the expert answers here?
  • Rather Not
    Rather Not Aug 15, 2008
    One of my model M7DH45B2A Maytag 45 PINT Dehumidifiers has started leaking as has been described. I have it hooked to a hose which goes to a drain pipe to the outside of the house. It is not leaking where the hose hooks to the plastic tube allowing external draining, but is soaking the shelf that the dehumidifier is sitting on, as well as the floor.
  • Rather Not
    Rather Not Aug 16, 2008
    This may not resolve tdmiller's problem, but I figured out my own problem. In simplest terms, my drain hose was plugged.
    I had noticed a couple of months ago that my bucket kept filling up (though the hose being hooked up should have bypassed the bucket completely). The flat area above the bucket always had moisture on it, so I at first assumed I had a leak. I also noticed what appeared to be a drain hole on the flat surface, but did not think much of it at the time. I think I must have re-positioned the unit to be tilted more towards the rear. What I discovered today is that the water was dripping into the back of the unit, then from there was leaking onto the shelf. I have unclogged the hose, and anticipate that I have resolved my own problem.
  • leakage Aug 22, 2008
    same problem. Had done it at other time but i took the vacuum cleaner to the front drain spout that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
  • popeyenj Sep 03, 2008
    Water is slowly leaking from the unit onto the floor. The hose does not appear to be clogged, the water collector is half full and the unit has automatically shut off as if full. The hose is connected directly to a drain. WHAT GIVES???
Sorry wrong model number. my model number is m7dh65b2a.
Posted on Aug 22, 2008
Dehumidifier leaks all over the floor, bucket is installed correctly and is not cracked
Check the drain pan. It is what collects the water from the condensor fins and funnels it to the bucket. Over time, dirt in the air contaminates the pan and builds up as a gunk which eventually blocks the flow.
Expect to need a towel or two to clean up. Often the drain pan needs to be removed by unscrewing it from the motor or disassembling the entire dehumidifier... hopefully, yours is one of the easier ones with a pull out slot. While you're cleaning the gunk, also check the fins to make sure they didn't get fouled and the hose to make sure it's clear as the same thing often happens there
Nov 29, 2017 | Dehumidifiers
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
Our machine is collecting water but I have a drip coming from the bottom onto the floor? It is coming from the behind the collection area?
This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
Sep 28, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
My dehumifier is leaking. The collector pan is fine. I took the covers off and could not detect anything. It is pretty simple...air blows by the coils, condenses, collects and runs into the pan. Looks...
TRY IT ON LOW FAN SPEED AND SEE IF IT LEAKS , MAKE SURE IF THERE IS A HOSE OR SMALL DRAIN PAN UNDER COIL   THAT IT IS CLEAN AND FREE OF DIRT .SOMETIMES ON HIGH WATER IS BLOWN PAST DRAIN PAN AND DRIPS ON FLOOR , THIS MAY BE A BAD DESIGN. IF THERE IS A FILTER CLEAN IT
Apr 20, 2010 | Maytag M7DH45B2A Dehumidifier
No water collecting, unit running
the collector base under the tubes just collects water and drips it through a hole into the water bucket. there must be a loose hose(if it has one) or the base collector or bucket has a crack, as they usually are plastic. also if the unit is sitting on a very uneven floor this will happen
Jul 24, 2009 | Goldstar DH3010B Dehumidifier
With an external pipe or even the bucket attached it seem to leak onto the floor below, what am i doing wrong
You may have a blockage in the metal or plastic collection pan under the coil that sweats to take water out of the air. Possibly some pet hair, lint etc. Have you cleaned it lately? Could the pan be rusted through somewhere? Is it level? Could you the collection bucket be cracked at or near the hose connection?
Jun 27, 2009 | Goldstar DH4010B Dehumidifier
Amcor tc100 started to leak on the floor but is still working
Ive had same issue with this machine. i opened it up and cleaned the plastic channels leading into the tank. Dust can collect and block these channels, diverting the water onto the floor. This cleared that problem, but now the fan is not working, so im hunting for one going cheap...?
Jan 12, 2009 | Dehumidifiers
Maytag M7DH45B2A Dehumidifier Logo
500 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
