Question about Weber Grilling
Need to know how to reset the LP Gas flow for a Webber 300 BBQ
    Brigadier General:
  • 4,736 Answers
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Posted on Feb 02, 2011
Testimonial: "thanks"
How do I convert a natural gas BBQ grill to propane?
You change the nozzle or jet or the complete regulator that regulates the flow of gas. I have seen some company's that will sell you the part or the regulator. You will have to go the the Webber and see if they even offer the part. Or maybe a BBQ dealer who sells and services Webber might do it for you. I know most companies will not sell the part or parts because of the liability. Good luck.
May 21, 2014 | Cook's Essentials Smoothie Maker Work Top...
Uneven burner
I apologize I've not logged in for some time and do not know what "everyone else" has had issues with.
I can tell you as a grill repair company we get 4-5 calls every week from clients complaining of poor flames, poor heat. The problem has a very simple solution and the problem is not the burners or other parts and (almost never) the regulator.
There are 3 safety features in an LP cylinder. One is a check valve that gauges pressure leaving the tank. This is a swing-arm pressed up by escaping LP. When the gas fills the manifold and gas line (because the BBQ valves all Must Be Off when the cylinder is turned on) the pressure pushes this swing-arm back into position.
The problem usually occurs with newly filled tanks because with the tank full and the OPD float displacing liquid pressure the gas "hits" the check valve swing-arm too hard so instead of registering the pressure leaving the tank the swing-arm is pressed too far and the back-pressure does not reseat it correctly.
The mechanics of the tank are designed to read higher pressure leaving and lower pressure returning as a leak and shuts-down. We still get some flow because of the OPD pushing but the tank will not allow gas flow at the necessary BTU's.
Reset: Turn off everything on the BBQ and the LP cylinder. Disconnect the cylinder and turn the BBQ valves all to "high".
Wait 5 minutes.
Turn everything off again -- and be sure every valve is completely off so no pressure is released.
Reattach the LP cylinder to the regulator and turn the tank on -- very, vert slow for the first full rotation so the gas pressure leaks through slow and cannot "hit" the check valve too hard.
Once the cylinder os all the way on light the BBQ and it will be fine.
Please let us know how it goes.
If I had one dollar for every time someone contacted us to buy burners, regulator, etc only to fix their BBQ while on the telephone with us ... I would retire!
Feb 09, 2014 | Jenn-Air Grilling
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Can a weber kettle be run on natural gas
They can be run on natural gas however since 2009 Webber stopped selling conversion kits for their grills. (Liability issues) Anyway the regulator in most cases and all of the burner orifices need to be changed. On high end grills it is a matter of changing the regulator and adjusting the burner orifices and air flow to obtain the proper burner fire. You may be able to contact a BBQ specialty shop and they may sell you a conversion kit after you sign a liability release form. Most will insist that you bring the grill to the store for conversion AND that they install the NG regulator at the place of use. By law.... all gas conversions must be performed by a licensed technician.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Weber Grilling
I have a Webber Q Family BBQ for about 2 - 3years. I noticed say last 6 months that the burners are not working properly and the grill is not hot enough ie take 3 times longer to cook a steak etc. I read...
OK, it sounds to me that when you changed the propane tank, you may have turned the gas tank valve on too fast. Doing so causes the built-in excess flow valve to check, which only allows a trickle of gas through. Do this: Turn off the gas tank, disconnect it and drain any remaining gas from the grill by opening a valve to a burner. Close the grill valve and then reconnect the tank. Very slowly open the tank valve and try lighting a burner again and see it that solves the problem. Douglas
Sep 12, 2010 | Ovens
The flow gas coming from the burner is very slow. only heats up to less than 200 degrees. even the side burner is the same. i've cleaned it and changed tank. what is my next step?
It could be a defective LP gas regulator or a restriction somewhere in the gas line for the bbq. This can also happen if the propane tank is overfilled.
First make sure that the LP tank is not overfilled. If you open the bleeder hole on the tank(small screw next to the valve) there should be no liquids coming out. If liquid propane is coming out then the tank is overfilled. Keep the bleeder screw loose until the liquid disappears then tighten. Re-connect the tank and see if that fixes the problem.
Then inspect all the gas lines on the bbq. Make sure that there are no kinks or crushed lines.
Then take a look at the gas regulator. Try turning on all the burners then give the regulator a couple good taps on the housing with something solid. See if the burner changes size. If it does and then goes back down it could be the gas regulator. Also take a look at the regulator housing. There should be a very small hole on the housing and it might be labled "vent". Make sure that this little hole is not plugged with any debris or that can cause a low pressure problem. You can use a sewing needle to gently poke out the hole. You will know if it worked because the burners will become much higher. And you could also try disconnecting the hose and regulator assembly from the bbq then turn on the LP tank slowly with the regulator connected. You should get plenty of gas flow from the end of the hose. Then use your hand to block and release the flow a couple times to try and clear any debris that might stuck in the regulator.BE VERY CAREFUL DOING THIS!!! MAKE SURE YOU ARE CLEAR OF ANY SOURCES OF IGNITION BEFORE TRYING TO CLEAR THE REGULATOR. Then reconnect the hose regulator and tank to see if the problem is fixed. If you are getting very low flow from the hose with the regulator disconnected then it is probably a defective regulator. They are pretty standard and you can purchase a new LP hose and regulator assembly from most home improvement stores.
If the regulator checks out good then I would think that there is a restriction in the main gas line for the bbq after the regulator. You will need you dis-assemble the main line and blow it out with some compressed air to clear the restriction.
Jul 03, 2010 | Brinkmann Charmglow 810-7400-S Propane...
I have a BBQ Galore STS 4-burner grill. How can I
You need to look at the orifices to see if the hole on it is big for Natural Gas and small for LP!
Mar 14, 2010 | Barbeques Galore Turbo STS 4-Burner 169544...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a...
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Jul 08, 2008 | Weber Gas Go-Anywhere Grill
Grilling Logo
606 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
