Question about HP Pavilion dv4000 Notebook
Windows won't start
My computer keeps going to a screen that says how would you like to start windows with the following options:
safe mode
safe mode with networking
safe mode with commad prompt
last known good configuration
start windows normally
i have tried all of the options and it keeps taking me back to the same screen
any ideas
i don't have the recovery disk
any help would be appreciated
  • gsusbuddy Nov 13, 2008
    I have the same thing happening with my HP Pavillion DV4000. Unfortunately every one of the options only goes to a blank "black" screen. I never get to option to delete any drivers or roll back to a previous driver. A day before this happened, I added a driver for the wireless adapter. That worked and I was able to connect to the internet with no problems. FYI...we have a damaged internal DVD drive (for some time now). When I close the dvd drive the computer attempted to restart, but now I can only get to the prompts as described earlier. I would remove the driver but can't get far enough in to do so. Can a damaged dvd drive cause a problem with start up?
  • 520 Answers
The reason it does this is because a program was interrupted before it finnished or a incorrect driver was installed.start up in safe mode to repair the problem.if you know of a new driver youve just installed either roll back to previous driver or delete it.
if unsure use check disk.when done restart.pc
Posted on Nov 10, 2008
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
Tip
How to Turn Off Safe Mode on Windows Vista
The Safe Mode is used to detect the technical and software problems in windows Vista. This is an effecting way to diagnosing the problem, that's why most of the technicians prefer this way to resolve the problem. But Safe Mode disables the most of the advance functionality of your computer. So use the Safe Mode only for diagnosing the problem and as you diagnose and repair the problem get back your windows to normal mode. <br /><br />For reverting back to normal mode at windows Vista, an option occurred which has to be select within limited time and if you select the Normal Mode option within this limited time, your windows will revert back successfully but if you waste the time, you have to restart your computer again for getting this option. You can select the Normal Mode option through arrow keys or by pressing the number at which the Normal Mode will appear.<br /><br />Sometime your computer does not display the Mode Selection Menu. This is not a problem you can get this menu and revert back your windows Vista into Normal Mode through the following instructions.<br /><br />Instructions<br />If you want to revert your Windows Vista into Normal Mode from the Safe mode but your system is not giving you option to select the mode, follow the given instructions: <br /><br />Restart Your Computer: To restart the computer you need to take the following step:<br />- Click on "Start" button at the left side of Task Bar. In Safe Mode of windows Vista the Start button appears at the same place where it appears in the Normal mode. Select "Turn Off Computer" from the Start Menu. Then, Select 'Restart" from the pop-up menu.<br />When your computer has been shut down place your finger at F8 key. As your computer starts to boot computer devices for restarting your computer, press F8 key again and again unless a menu appears on the screen. This menu is Mode Selection Menu.<br /><br />Note: If your computer won't give you Mode Selection Menu at the screen that's means you have lost the time of getting option. In this condition restart your computer again and again, and then press F8. <br /><br />When you get Mode Selection Menu on your computer screen, stop pressing F8 key. Now choose the Normal Mode from the list by the following method:<br />- You can select the Normal Mode by pressing the number on which Normal Mode appears in the list.<br />- You can select the Normal Mode manually through the Arrow Keys. Press the down key to reach at the Normal Mode option in the list and press Enter. <br /><br />Then wait for a while to reboot your Windows Vista in Normal Mode. <br />This is the method of changing Mode in windows Vista. You can follow these instructions at any time to revert your windows Mode.
on Jun 24, 2011 | Computers & Internet
Seme olvido un pass woork
Step 1: Enter Safe Mode
a)Start or re-start your computer.
b)Before the Windows 7 loading screen appears, Press 'F8? to enter Advanced Boot Options.
c)Use arrows to choose 'Safe Mode' when you can see the Advanced Boot Options screen.
d)Press 'Enter' and wait for Windows 7 files to load.
e)Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3 options are all available for you. Here above we take Safe Mode as an example, but if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to reset the password.
Step 2: Reset the forgotten Windows login password in Windows 7
Now you could diagnose and solve some serious computer problems in the safe mode and reset the forgotten Windows login password in Windows 7 as follows:
1.Click 'Start' button, input 'lusrmgr.msc' into the Search box and press 'Enter'.
2.In the 'Local Users and Groups screen', click 'Users'.
3.Right-click the account that you need to reset the password for, and then click 'Set Password'.
4.Type and confirm the new password, click 'OK'. (You can go to 'Local Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
Jul 19, 2011 | Computers & Internet
How to open a forget password and username on password
a) Start or re-start your computer.
b) Before the Windows 7 loading screen appears, Press 'F8? to enter Advanced Boot Options.
c) Use arrows to choose 'Safe Mode' when you can see the Advanced Boot Options screen.
d) Press 'Enter' and wait for Windows 7 files to load.
e) Log on with an administrator account when you can see the log on screen
1. Click 'Start' button, input 'lusrmgr.msc' into the Search box and press 'Enter'.
2. In the 'Local Users and Groups screen', click 'Users'.
3. Right-click the account that you need to reset the password for, and then click 'Set Password'.
4. Type and confirm the new password, click 'OK'. (You can go to 'Local Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on desktop.)
Jul 17, 2011 | Computers & Internet
How do i bypass password
Jul 17, 2011 | Toshiba Satellite A35-S159 Notebook
My hp pavilion a820n computer will turn on but won't start up
As the computer is starting up keep hitting F8 until you come to the boot options screen. Once in the boot options select "Last Known Good Configuration" and see if it will start. If it still will not start then try and see if the computer will boot in safe mode (Do the F8 thing again until you reach the boot options screen again and click on "Safe Mode").
If it will not load into safe mode then you may need a Windows O/S Reinstall.
Jul 12, 2011 | HP Computers & Internet
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
How to go in safe mode?
to go into safe mode, turn on your computer and constantly press F8 immediately. You will press the F8 button at the first black screen, that is, when your computer displays its log.
While pressing the F8, a windows option will be the next screen to appear, amongst the windows option, you will see safe mode there, use your keyboard arrow key to scroll to safe mode and press enter.
By now,your computer should be loading on safe mode.
Good luck.
May 18, 2010 | IBM ThinkPad R51 Notebook
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
My toshiba satellite a105-s171 will not boot up. it acts like it is starting but after the windows xp screen a blue screen flashes with white lettering but does not stay long enough to read and then the...
You need to do a recovery using the recovery console. There is an option during startup, if you are running XP or later, to press F11 for emergency recovery.
Press F11 and choose the option to recover and backup.
This will backup all files and programs currently installed on your computer.
After the recovery process finishes, you will have to go through the process of setting up your computer, like you did when you first bought it.
After you are all setup again, it is a good idea to create recovery disks under the 'Start' menu, 'Recovery' option.
Apr 12, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
