Question about Compaq Armada M700 Notebook
M700 won't work on battery anymore
M700 worked fine on battery, until after a time of not using it on battery, it just would not boot on just the battery.
I have checked the battery and all the indicators go on. The battery program in Windows (XP) says that the charge is at 100%.
With the battery in, and A/C unplugged, it will not boot. With battery in and A/C connected, it boots and works fine. If I disconnect A/C at this point, the computer dies.
  • KCEFF Aug 09, 2008
    Thanks for the information. I'll try a new battery - this one IS getting long in the tooth!
    Thanks
    Genius:
  • 2,028 Answers
This could still be a bad battery, even though the indicators and the machine are telling you that it's charging. Laptop batteries are a bit more complicated than regular batteries, they have built in fail safes in order to keep from damaging the machine if the battery malfunctions. If a fail safe has engaged due to a malfunction this could cause the problem. Start by trying a new battery. If a new battery doesn't cure it, then the problem may lie with the power management system on the motherboard.
Posted on Jul 20, 2008
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Windows 2000 Pro Armada M700 Boot Up Problem
plz check is there any option for start your computer in last known good configuration if yes then you try it. you will get in safe mode screen
Jun 30, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
M700 not booting
Borrow a cd from someone with the same version of windows as you have. For example xp pro or vista. Boot from the cd as go along as if you were going to reinstall. If XP select enter, esc, f8, then r. Those are the answers to the screen questions. In vista boot up the cd then select repair reinstall. It will remove windows files and leave everything else in contact then it will reinstall windows without harming programs or files. It kind of rebuilds itself.
Mar 01, 2008 | Compaq Armada M700 Notebook
Power
are you sure your get ac power, im thinking you ac plug in the computer is loose.
Dec 17, 2007 | Compaq Armada M700 Notebook
Trouble booting up laptop
Goto a radioshack and ask if they can give you a replacement AC adapter for the computer. Bring the computer with you so that they can match it up. If the computer charges and works with the new adapter, it was the plug/adapter that you were using. If it still does not turn on, it may be a problem with the socket for the power adapter and you will need to have a certified repair technician take a look at it
Jul 28, 2007 | Compaq Armada M700 Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
