This is a waste ink code and needs to be reset. follow instructions below.
Canon
pixma iP90 released almost at the same time with canon Pixma iP 1880.
Canon iP90 is printer with single function. Cartidges which used in
canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure
canon iP90 almost the same as manual reset canon iP1880. You can use
combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
- Before resetting printer canon iP90, start with printer power off .
- Press resume button coincide with power button.
- While pressing power button, release resume button.
- Press resume button 2 times and then release both button
- Green LED indocator will blinking and then stopped blinking.
- When the Power LED lights in green, press resume button 4 times.
- Press power button and the printer power will off. otherwise off, depress again power button.
- And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
