Question about Kenmore 22422 Top Load Washer
Same problem The Kenmore 70 series top loader washes and agitates but won't spin or drain. I have lowered the hose to empty the washer and was successful. I tried washing a short cycle and it stopped after the wash and agitate before the first spin and drain. So I assumed that the hose is not blocked. How do I tell if the pump is blocked? How do I get to the pump? How likely is this the pump? Is it worthwhile to fix or just buy a new washer? Look forward toyour response. epuschec@med.wayne.edu or drappole@gmail.com
    Genius:
  • 1,028 Answers
Ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Posted on Jul 22, 2008
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
185 people viewed this question
Sal De
fordexpert
Robert Rankin
