HANNS.G monitor has a Blue Box in the upper left corner of the screen which will not go away. ( 14 lines of various information in the box) 1st Line= LRW778HZO2O1RHNK2-TOO 13 More lines with other info AUTO COLOR Gain Offset etc.-- My telephone Number is 636-227-9236
Grandson fixed error
Posted on Jul 22, 2008
Blank Blue square on left hand corner of the screen ??
It might not be the same issue, but we had a blue square in the upper left hand corner of our hanspree. To fix it, either press the button headed 'pip' or go into menu, down to calibration and then uncheck the box titled 'pip' there. I hope this sorta yours as it did ours.
Nov 10, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
I HAVE A HANNS SG MONITOR JW199D WHAT IS HAPPENING IS: the OSD NEVER LEAVES THE SCREEN! IT BLINKS I PRESS 1 FOR EXIT BUT IT RETURNS. DO I NEED A DRIVER ? I HAVE NOT A CLUE WHAT TO DO TO GET THIS BLUE BOX...
There is no need for drivers at your problem. Just check out the area around the buttons (and the buttons) for "locked in press status" case. In other words I suppose that one of the buttons is pressed and keeps the OSD on. Try pushing them to feel the click of the button.
Post back with the results.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 07, 2010 | Hanns.G Corporation JW-199DPB 19" LCD...
My picture is smaller than the screen size.
Dear User,
This usually happens by selecting the wrong screen resolution or the resolution not supported by your Monitor.
However you can solve this by getting into the "Safe Mode" .
  1. Press the 'F8' key just before the windows logo appears.
  2. It presents a Menu with various options.
  3. Select 'Safe Mode'.
  4. You can now use your monitor here
  5. Now login as usual.
  6. Right click on the Desktop and go to Properties. In Setting use the lowest screen resolution. Click on Apply - OK.
  7. Restart your system properly.
  8. And you find everything OK again.
Thanks
Jan 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
Lines on upper left corner, inside of screen
its problem with the display cable (not the one you connect to your pc)
open the lcd display and look for a cable that is attached to the front glass display. check whether it is dameged.. it cannot be replaced
you need to replace the whole display that would be better. and cost effective
Jun 11, 2009 | Princeton Digital VL1918 Monitor
WD My Book 1TB - can't recognize usb drive
1 go to the start menu
2 Right click computer
3 Click manage
4 Go to the storage tab and open it (its in the box on the left side of the screen)
5 Click disk management
6 look for your unusable drive.
7 If the bar is black and it does not say online then you are going to right click the small box on the left side that says "disk X"
8 Pick the 1st option
9 after hitting next a time or two you will have 2 choices to pic from one says something like mass boot or something along them lines do not select that one pick the 2nd option.
10 Hit next till the window closes
11 If the bar is still black right click the black bar
12 Select 1st option
13 Hit next till you see a box that says something like quick format and check that box.
14 Again hit next till its finishes
15 after you finish that the window should show the box with that black bar turn blue and the box on the left will say online.
Sorry i dont have all the terms but i just got help myself and trying to help you all out as well.
Mar 12, 2009 | Western Digital My Book Essential 1TB...
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
