Question about Zenith ZN620 Remote Control
Zenith zn620 universal remote
I am trying to program my new tv, but don't have the code book. How do I program my Zenith tv?
In case anyone ends up seeing this in the future, there is an alternate way of programing devices with the Zenith Universal Remote other than just direct code entry.
It's a sort of automatic searcher, and the process goes like this:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes
channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Posted on Oct 14, 2008
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Posted on Aug 28, 2008
We need a Universal Remote Control Code for a Zenith TV
Four digit universal remote codes for Zenith TV are:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Jun 27, 2012 | Zenith ZN620 Remote Control
ZC800 program codes for EMERSON T.V
go to www. fitness.manualsonline.com or www. remotecodelist.com
God bless yu
Jun 20, 2012 | Zenith ZC800 Remote Control
Codigos del control remoto zenith zn620
Helo
Tres d?gitos a distancia universal para Zenith son los siguientes:
000 / 001 / 004 / 023 / 038 / 058 / 059 / 064 / 121 / 135 / 136 / 153 / 0016 / 0017 / 0092
Cuatro d?gitos de los c?digos de control remoto universal para Zenith son los siguientes:
Entrada directa de c?digos
1.Pulse y mantenga presionado el bot?n SETUP hasta que el indicador rojo permanezca encendido y luego suelte el bot?n SETUP.
2.Pulse y suelte el bot?n del modo deseado (TV, VCR, etc.) El indicador rojo parpadea y luego permanece encendida.
3.Introduzca el c?digo de 4 d?gitos a partir de las tablas de c?digos. Nota: despu?s de una entrada de un c?digo v?lido, el indicador rojo se apaga. De un c?digo no v?lido, el indicador rojo.
4.Con el dispositivo, la prensa de canal hacia arriba. Si el dispositivo responde, sin necesidad de programaci?n adicional es necesario. Nota: Si algunos botones no funcionan el dispositivo, pruebe uno de los otros c?digos para su marca
Aug 04, 2011 | Zenith ZN620 Remote Control
Lost book on remote need zenith codes for rca remote to program tv
Which RCA remote are you using? RCA Universal remote codes are available at the code finder: http://rcaaudiovideo.com/remotecodefinder/ . Enter the model and then the device in the two drop down menus then click Search.
For example the Zenith codes for the RCR312W are 11423, 10017, 10463, 11265, 10178, 10030, 11145, 10145, 10092, 10016 .
Please note that codes programmed in the remotes are usually limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
Jun 21, 2011 | Televison & Video
I have lost the book to code a Zenith TV Could you help me find the code Please? I had it coded to another TV which died so now have a Zenith & now I cant find the book on how to code the Universal...
I couldn't find the manual for the remote you specified, however, as long as it is a Philips remote, you should be able to use any manual to find the code. If you know how to program the remote but just need the codes, you can get the codes here:
http://www.p4c.philips.com/cgi-bin/dcbint/get?url=/sca/sca/091116/091116160956_30167.pdf&ofn="H15022.pdf"
Dec 20, 2010 | Philips 313923812851 Remote Control
My universal remote needs a code to be programed to my tv. my tv brand is zenith
There are many codes for Zenith TV's. First, try this website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Note if your remote uses 3-digit codes or 4-digit codes, and choose the appropriate code list.
May 02, 2010 | Universal Remote Control GE174Universal...
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
Jan 15, 2009 | Zenith MBR3447 Remote Control
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Zenith ZN620 Remote Control Logo
751 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
