Question about Executone IDS 82200 Corded Phone
Program error I have a executone dsp 29k 82600 phone system that is displaying program error on main display. I recieve calls in but can't dial out.
    Problem Solver:
  • 10 Answers
What system is this?
does the Program error apear when you press a button?
if it does, then the keys need to be reprogrammed.
let me know and I will help you with the rest.
Posted on Dec 07, 2008
How can I change the system main greeting on an Executone Model 64?
from any phone dial 436 and then press #, then enter managers mailbox usually 5000 and the password, by default it is 5000.
then 3, 8 and 1# for CCR 1,(or 2# for CCr2 and so on) and follow the prompts
if you need additional help, call me. 2033955027. Joe
Sep 05, 2014 | Executone 64 Corded Phone
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
Change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
Mar 11, 2009 | Panasonic KX-T7630 Corded Phone
Partner 18 phone has long distance blocked
There are a bunch of ways to accomplish this.
FIRST. When you say you cant dial long distance. What happens when you do? Do you get an error tone from the phone system? Or do you get a recording saying you cant dial long distance?
If you get an error tone, there are still a few ways to make this happen, so report back.
Nov 14, 2008 | Lucent PARTNER18 Corded Phone
Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Nov 12, 2008 | Executone 64 Corded Phone
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
Executone 64 Administrators manual
if you can get into the programming then first go to the B screen and then press A and set the drop pulse to 10 and then press C for Copy and then Y .
hit ESC and press J
the cursor should be blinking on the first line on top left corner, there hit F for Flash and press ENTER
Hit ESC and press A , put in the EXT you need to program the key for, then press Enter, then K, then K again and pick a key to programm. once you have picked one by pressing ENTER key to move the cursor program a code 815 ENTER, S for Subcode and then 1 Enter
ESC, ESC E for exit.
contact me for more info
Apr 17, 2008 | Executone 64 Corded Phone
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Executone IDS 82200 Corded Phone Logo
125 people viewed this question
Top Executone Lands Phones Experts
David Burbee
David Burbee
magna buff
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
