Question about Frigidaire Ovens
Frigidire Deluxe cookmaster
We received a old frigidaire deluxe cook master from a friend It like new but we didn't receive and owners manual and we can't get the top oven to work. we are trying to locate a owner manuel. I'm not sure if this is the right model number RBE97K It was hard seeing
SOURCE: inquiry on parts for ancient Frigidaire Cookmaster
Try www.monitortop,com and send email
Posted on Jan 01, 2008
  • 409 Answers
SOURCE: free owners manual
hi there,
go to
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
Posted on Sep 14, 2008
  • 30 Answers
SOURCE: I need to purchase a new heating element for
you will need to call the parts store directly and ask them to order the part or if they know where to get it. My guess is that with the unit being that old, your part is obsolete.
Posted on May 03, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
  • 15935 Answers
SOURCE: Kenmore Elite made by Frigidaire
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
I just bought a about 35year old house it has a chef contessa deluxe gas freestanding oven and warmer i don't know the model no can you help i need a manual and parts
Hello Helen, most model number labels can be found either under the cook-top surface burners; on the side of the oven unit; or in the back near the vent. Other places to consider, behind the oven door jamb along the top or side edges. If your particular stove unit has a kick plate, you may find the oven's schematic attached to the inside of the kick plate with may contain the technical data to your unit. Hope this helps.
Feb 12, 2017 | Ovens
Is the oven temperature in Celcius or Farenheit...I tried to heat up oven to cook chicken and it only goes up to 287 degrees....
It should come programmed with ?F. Have you tried to cook anything in the unit to measure the temperature? That would be another way to easily tell. Set it for the highest you can get it and bake something you normally would be at a lower temp for lower amount of time and go from there.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Heating Elements
Try Affordable Appliance They have older look-up and still have lots of older parts to revive those older units. Once on their home page, hit request form and fill out the request in it's entirity for fast and accurate assistance.
Apr 19, 2012 | Frigidaire Ovens
We bought a house with an old wood combustion oven everhot deluxe 204. Unfortunately all the controls details have been erased with time. So we do not know where the highs and lows stands for the knobs. We...
Hi Jacqui and Sven,
Check these guys'll have to call or write, but they should be able to answer any (and all) questions about the Everhot Deluxe 204. They even carry spare parts! Hope this helped.
May 06, 2011 | Ovens
I need to purchase a new heating element for this double eoven range (right Side)I believe the model is from 1969 but is still in great working order. I think the model # is RCDG-71P but the parts website...
Apr 19, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Inquiry on parts for ancient Frigidaire Cookmaster
Jan 01, 2008 | Ovens
Ovens Logo
767 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
