Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Diagram for changing out the brushes on the motor. Model #MM575. Also may need to replace the switch.
    Champion:
  • 313 Answers
See www.toolpartsdirect.com .look for black & decker icon.
u have to enter model #
Posted on Jul 23, 2008
  • mr aicnelav Jul 24, 2008
    sorry wrong info. open top cover of the mower. you will see a + sign on the top black bearing cover thats the red wire. other wire black for - negative.
I need the electrical motor P/N 90565704-04.
Do you need a new motor or is it just the brushes which need replaced? Firstly unplug the machine and disassemble the motor or gain access to the brushes, found on either side of the motor at one end only. Remove the brushes (they usually unscrew behind the black caps), if they are burnt or look badly worn or are less than 5-8mm in length, replace them. The BRUSH is the black carbon rectangle of hard material at the end of the brass spring. New brushes are often 25-30mm in length as a guide. Based on that information you then decide if new brushes or a new motor is the answer. A quick tip; If you remove the motor and clamp it safely, connect the correct voltage to the motor lead and switch on long enough to establish if it is working and running freely. If you cannot find the parts locally, try www.4ourhouse.co uk.
Apr 17, 2016 | Black & Decker Black and Decker Mm575 18"...
Motor won't turn on
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Can't find the switch for my mower model mm575
You can find any part you need for it at this link
Here is a direct link to the switch
Please take time to rate this.
Jul 05, 2011 | Black & Decker 19" Electric Lawnhog...
Brush roller wont turn, motor is good and the curcuit board appears fine. No evidence of anything blown or broken wires either.
Judging from this parts diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Dyson-Inc-Parts/Vacuum-Parts/Model-DC15BALL/3207/0645000/50026393/00001?blt=06&prst=&shdMod=
The brus motor has what appears to be a transmission on it.
If you have it apart apply power and make sure the shaft that fits brush is turning.
If the motor spins but the shaft does not you need to replace the motor asm
If the shaft spins the problem is with the brush or the way the shaft attaches to the brush
May 21, 2011 | Dyson DC15 Animal Bagless Upright Cyclonic...
Electric mower keeps slowing down and stopping
Two things come to mind. The brushes in the motor should be replaced. (Get them at a local motor repair shop, but take one of them in with you to get the correct one). If that is not the problem it may be the switch in the handle that you turn it on and off with. The switch may be corroded or bent. Good luck...Lee
May 29, 2010 | Black & Decker Black and Decker Mm575 18"...
Tornado wide area commercial vacuum
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Tornado 93030 Wide Area Carpetkeeper...
Hilti how do i change brushes and where to buy them?
i'm sorry to say that the brushes are not sold seperatly. you will have to replace the whole motor. if you email me paul@wysehire.gi and tell me the exact model you have, i will be able to send you a parts diagram.
I hope this helps.
Nov 06, 2009 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
192 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
