Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Mag Innovision LT982s 19 in
Power LED went out and so did the monitor. Suspect it's a power supply problem, but I have no schematic to go by.
  • eectac Jul 21, 2008
    I have a Mag Innovision LT915s. The LED does not come on and the monitor does not work. Please help me troubleshoot. Could it be the cord or power supply?
Yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
Posted on Feb 10, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mag Innovision Master
  • 848 Answers
Power LED went out and so did the monitor. Suspect it's a power supply problem, but I have no schematic to go by?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0100B Lien Chang 860 ALZ GJ712D EH Power Supply Backlight Inverter
Posted on Mar 22, 2015
I have a mag innovation flat screen computer monitor but I need the power cord for the monitor it is a LT717S model # 700P made in 2006
The power lead you need for this monitor is a standard EU 3 pin. you can purchase these from any good electrical or computer store.
The look like the old Kettle plugs if its of any help
Jul 24, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
Power will not come on
Is there a separate ON/OFF "rocker" switch, in addition to the ON/OFF button on the front of the unit?
Have you tried a different power-cable?
If all else fails, take the monitor to a qualified technician, for more trouble-shooting.
Jan 16, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
No sound from the monitor
Go to control panel and find volume sound and put the WAVE up on line.
Vitally
Jun 02, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s screen problem
Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that there is ** backlight(s) and/or it is **t receiving power from the inverter.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are k**wn cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Mar 09, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Monitor LT982s model900p
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Oct 02, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
2,169 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
