To answer that question you need to follow the plug wire from the # 1 cylinder to the cap. #1 cylinder is the first cylinder located at the far from of the drivers side portion of the engine. (left side) The cylinders are numbered even and odd, so 1,3,5 left and 2,4,6 right. The firing order is also located on the intake manifold directly in front of the distributor.
The firing order for a Chevy s10 depends on which engine you have.
1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise.
2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise.
4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
The cylinder closest to the passenger side is number one. Firing order is 1, 4, 3, 2
Where is your coil pack located in reference to the engine? I need this info to give you accurate placement of the spark plugs.
Charlie
