Question about Philips 60PW9363 60" Rear Projection Television
Red sideways hourglass
I have a 60pw9363 and im getting like a red sideways hourglass. its like a red shadow arch on the top and bottom of screen. there is a red shadow like 3d on picture. I tried to adjust the convergence but the red wont move enough to align. sometimes if i turn the set off and on about 6-8 times its ok, but if the screen on the tv changes then the red is back. i talked to a tv repairman over the phone, he said it was the red tube, be $500 to fix. seems like after reading a little here that it might be ICs. Can you help me with this problem? and parts i might neeed?
  • EggbertsMom
    EggbertsMom Nov 20, 2008
    Same thing happened here. We were able to adjust it out enough to watch TV somewhat normally, but there is a bend to everything. How do I remove and replace the fried chip? How much will it cost to have a repairman do it?
  • Anonymous Dec 29, 2008
    My problem the same the red ofsets the red. When the problem first started I could Turn it off turn it back on quickly it would fix the problem.Now Its permanent. Can adjust a little but wont completely get right!
    mata31
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.red sideways hourglass - 2c07611.png/>2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set thared sideways hourglass - 578ba6c.jpg fluid changed.
578ba6c.jred sideways hourglass - 65af323.jpgh_mi
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
Same problem here but red convergence adjusted OK - leaving black sideways hourglass distortion. Help!! [what is ICs?]
Posted on Sep 28, 2008
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Philips 60PW9363 60 in. Rear Projection Television, red sideways hourglass
You can get the Kit at the following link which contains both ICs and the 12 Convergence resistors plus free instructions on how to do the repair. Its listed under their Convergence repair kit category and its called the DPTV305 - DPTV345 convergence repair kit. Here is the link.
Nov 24, 2008 | Televison & Video
Convergence. shadowing, arch top and bottom, red and green colors
You have a convergence problem. i see these set all the time at shop. first consult the article in tips and tricks section the fl231 fuse problem. it might provide some answer and might turn out to be a simple repair. If you do not have the convergence option under setup in customer menu then i say you have that problem.. otherwise it sounds like a convergence power board issue. if you have the options try autocovergence first and then if that fails try manual convergence of red and blue if the dont move then it will be convergence power board. let me know and ill try to talk you through it
Oct 06, 2008 | RCA HD52W59 HDTV Projection Television
Nintendo DS The Legend Of Zelda
First of all, this crest is VERY difficult to draw correctly
But have you ever tried to draw the hourglass instead?
Sep 26, 2008 | Nintendo The Legend of Zelda: Phantom...
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
203 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
