My church has a overhead projector that they say keeps blowing out the bulbs. i have looked at the wiring for shorts and everything looks good. is there a component I should look at or could they be using the wrong bulb?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
How much V is it suppose to have and how much is it getting in the bulb? what is the max Wattage for the bulb? are they sing the type of light for that machine? Is it anywhere they plug it in or is it that particular plug?
Posted on Jul 21, 2008
I have a older overhead projector that I need a bulb for but can't find the right bulb where can I find the bulb at......
You can provide the model # for the projector or possibly look at the actual old bulb to obtain any identification data from the bulb - such as a part #.
Here is a link for 3m replacement lamps:
3M Canada Office 3M Overhead Projector Lamps
Jan 06, 2015 | 3M Office Equipment & Supplies
Keeps blowing lamp
Don't touch the bulb with bare hands. grease from your hands will make the bulb blow out
Oct 05, 2013 | 3M Office Equipment & Supplies
After bulb burns out during church service and fan is running when power is turned off and bulb is replaced. Projector will not power back up.
Hi, I would suggest that you give it more time to cool down in the future, that is why bulb burned.
There could be more heat damage to projector. Check for reset botton and push carefully. listen for click. Look at main switch with more detail (worn out) Bring to be repaired. Good luck.
Jun 13, 2011 | InFocus DP8200X R Refurbished LCD...
I HAVE AN OVER AN OVERHEAD PROJECTOR ONE OTHER CHURCH WAS DOING A PROGRAM AT MY CHURCH TYPE THERE NAME ON THE PROJECTOR AND THE NAME OF THAT CHUCH IS ENBEDED ON TE PROJECTOR: HOW DO I GET IT OFF
Go to the menu settings & change the display logo back to factory or press reset to factory original settings. The other church simply put in their logo.
Apr 14, 2011 | Dell 1209S DLP Projector
Bought new bulb for projector buhl 2900 but still not working.Fan comes one but no light
Like many overhead projectors, the Buhl 2900 can accept TWO projector bulbs (the operating one plus a spare). Make sure you inserted your replacement bulb in the slot for the operating lamp. There is a slide lever on the front of the unit that allows you to quickly switch to the spare lamp. Turn off the projector and move the slider to switch to the other bulb slot. See if that does the trick. Good luck!
Nov 22, 2010 | Buhl 90 Series Open Head Overhead...
My overhead projector...it does not light up....the fan goes on but no light.
projector goes on then goes out. orange light on solid and flashing blue.
have had optoma look at it they said it was bulb.
Oct 23, 2009 | 3M EVW Overhead Projector Replacement Lamp...
NEC Overhead Projector
Hi Forrest
This sounds like a damaged Mainboard.
First check if your Projector is still under warranty as this is a very expensive part to have replaced.
Also check if it has any effect whatsoever using another PC Cable.
Hope this is of help.
Mar 29, 2008 | NEC VT47 Multimedia Projector
3m Pverhead projector not working need help!
Check for corrosion where the bulb sits in. Is there a fuse required. Make sure you handle the buld with cotton gloves (oil from hands not good) Let me know if that works.
Dec 01, 2007 | 3M - EVD Projection Lamp for Overhead...
48 people viewed this question
k24674
jasbo
jasbo
