AEG Lavamat 16830 washer dryer
Waste pipe split on installation - I have a new pipe but can not see how to remove old one and fit it as it seems to be integral - please advise - thanks
AEG 16830 CODE E20 .NOT DRAINNING
Posted on Feb 01, 2013
Can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Posted on Apr 08, 2010
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
Waste Pipe
you haven't said a make and it is presumably a washer but:
waste pipe clips usually onto a spigot on the pump housing. should be accessible by tilting machine backwards. on some machines easier to remove the back plate
Jul 20, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
305 people viewed this question
Top Washing Machines Experts
