Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer and dryer
I am having trouble with my washer. It comes to the rinse cycle and starts to drain the water out of the tub, it will not spin and stops working. It smells like something is burning. The motor works find during the agitation cycle. Can you help me? All I have is number 417.90817990 for the washer.
  • ToddFinner Jul 29, 2008
    The washer will not go to the spin cycle. Smells like something is burning and shuts off. Now we're stuck with a full load of clothes and wash water.
  • Anonymous Aug 04, 2008
    same problem
    Champion:
  • 210 Answers
Check the belt, pulley, & idler pulley assy.
Posted on Aug 07, 2008
I have a stackable Kenmore washer and dryer When I start the washer it will fill up and try to start then it will make a beeping noise and drain then it will beep again then stop I tried to switch cycles...
You have a clogged drain line their should be a plastic filter inside the washer located on the main drain line remove the plug clean filter and snake hose if ness. Make sure you have a container to catch water if not drained all the way
Jan 15, 2014 | Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stackable washer/dryer (apartment size) and the washer will shut off when it goes into the spin or rinse cycle. If I turn the control knob to rinse or spin, nothing happens. The washer...
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Jan 31, 2010 | Kenmore Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
449 people viewed this question
Sal De
fordexpert
Robert Rankin
