Question about Sony PlayStation Portable (PSP) Console
Psp what is aoss button
  • 55 Answers
AOSS (Air One-Touch Secure System)
It's wireless router application that provided by Buffalo Inc. So when you're connect to the WiFi network, you doesn't need to input any password or SSID. Just simply touch the AOSS Button on the Wireless Router, and you'll get connected.
Any questions? Feel free to ask me =]
Posted on Jul 08, 2009
The games play them selfs
Posted on Jul 20, 2008
Midwest-tech
  • 243 Answers
SOURCE: Can't find AOSS Button in psp
you are doing it in the wrong menu. you are setting up a connection to location free player
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly. first you need to have a wireless internet at home. next you need to turn on the wlan on your psp, located at the left side corner of your psp. search for a wlan around you. if its not secured, your lucky, you can connect anytime, but if it has a wep key, you need to find out the key to be able to connect. Switch the wlan button (located on the left side) to on and if don't aoss router seperate from the psp you cannot use automatic. So goto new connection and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
Posted on Jun 17, 2008
SOURCE: where is the aoss button on psp
aoss is on the router
Posted on Jun 29, 2008
jayzee140
  • 31 Answers
SOURCE: WHERE IS THE AOSS BUTTON O A PSP
No, there is no AOSS Button on the PSP. You have to have a router. This router is hooked up to your computer and is around a $100.00 but you have to have DSL or something like it to run a phone line though. If you do not have this you can go to a Holiday Inn or Wal-mart parking lot who has this router hooked up already. You can access to the internet there.
Posted on May 31, 2009
Tekmekanik
  • 34 Answers
SOURCE: i cant find the aoss button on my psp
That's because there isn't one.
HERE
is a good guide that should have your PSP on-line in no time.
please rate my solution.
Posted on Jul 09, 2009
  • 16 Answers
SOURCE: Where is the AOSS button on my PSP slim
look on commputer
Posted on Nov 30, 2009
Where is the aoss button at on psp
HI. This question and issue is one of the most misunderstood attributes of the PSP unit. Essentially; The AOSS Button and indicator are on your router. This is not on the PSP hand held device, at all. With that said; There were some earlier models that actually had this particular button on the top right side of the device. This has been removed and is not part of the newer PSP designs.
In order to connect an AOSS-enabled client(PSP) to a compatible router, you first will need to press the router's AOSS button for 3-5 seconds; which illuminates a flashing amber indicator on the unit. This puts the router into "AOSS mode," during which it can accept configuration requests from AOSS clients. Make sure you align your PSP Parallel with the router to get Max signal strength.
NOTE_ There are some routers on the market(low level), that are not equipped with this feature.linksys models will be one of those none AOSS compatible brands, among others.
Nov 30, 2010 | Video Game Consoles & Games
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your psp using it.
The psp does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices like your psp for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set up the devices in this manner.
here is the steps for setting it up if you did have this feature on your router.
1)To use this set up for the PSP go to Settings>Network Settings> infrastructure mode>new connection>automatic - AOSS. At this point the PSP will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
again this only works if your router has the AOSS button. and it is not found on your psp.
May 12, 2010 | Sony PlayStation Portable (PSP) Console
Where is the aoss button on the psp console?
the aoss button is not on the psp it is on another device on that device you press the aoss button to connect the psp to it
Jan 12, 2010 | Sony PlayStation Portable (PSP) Console
Were is the aoss button on the psp
You should find the aoss button near the power on/off button. Older PSP models dont have aoss button in which case you need to set it up with the router.
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
I cant find the aoss button on my 1000 verson psp
Near the right side of you psp if it is new there should be a small button near the power button that is the aoss button.
Jun 19, 2009 | Sony PlayStation Portable (PSP) Console
The psp doesnt have an aoss button- this is located on your reuter but very few reuters have this feature.
May 27, 2009 | Sony PSP (Piano Black)
May 26, 2009 | Sony PSP (Piano Black)
Weres the aoss button
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think there is no AOSS button on your PSP. AOSS is a wireless solution made by www.buffalotech.com. Most new wireless routers/access points has this capability. AOSS is on the wireless router/access point and not on the PSP.
AOSS will automagically determines and configures the connection of a PSP to a wireless access point by pressing the AOSS button on the wireless access point.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
AOSS BUTTON?
its on the on your left side
Jun 05, 2008 | Sony PlayStation Portable (PSP) Console
Where is the aoss button on psp
The aoss button is not on your psp Its on your stick, hold down the left on your stick. <> It will start blinking. if you dont know what i mean still.There are to lil simbles on your left of the psp They are very small. up just a little bit is a stick.sometime you use the stick to operate your game.(move) Click the left of it. If you dont get that then your ******* stupid
Mar 18, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
