Question about Whirlpool GHW9400 Duet Washer
Washer problem i have a whirlpool duet washer and evry time i start a new load it eventually will quit and f21 will blink and appear on its small screen. i think theirs a probl;em with it draining but what does f21 mean and how can i fix it?
    President:
  • Whirlpool Master
  • 662 Answers
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 28, 2010
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F21 error message - whirlpool duet front loader washing machine - appears that water starts to flow into the machine through the soap dispense, the cycle starts and no more water flows into the machine....
Hello, welcome to fixya. Based on your post I understand you have a "F21" error problem with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know. It is not related to filling. If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is) http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony. Regards, Macmarkus :)
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
Regards,
Macmarkus :)
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Mine has F21 blinking. What is wrong?
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Aug 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem with whirlpool duet
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
