Kodak EasyShare Z885 Digital Camera Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have to reset time and date every time the batteries are changed
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 284 Answers
  • Posted on Feb 02, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
284
Questions
Helped
55964
Points
744
Change the internal battery - a circle flat
  • Anonymous Feb 29, 2012
    and were is it?
    how can I change it?
1helpful
3answers
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
How to Clear Your Computers CMOS to Reset BIOS Settings
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
1helpful
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
After battery change on my 2001 avalon the time/date reset to default even I set the time/date correctly then turn off the ignition and turn back on again then the time/date reset to default again .
If some connections were changed then the ALWAYS ON +12 volt to the clock circuit back up is not powered all the time . check if while the battery was changed if there was any link that was disconnected that is the continuous supply to the clock.
Bios date is not being saved
it has to be the battery contacts, the motherboard is loosing contact with the battery which is why it keeps resetting itself
My date has to be reset every time I turn on my computer. How do I ensure the date and time is memorised thereby avoiding resetting. Thank you.
most of the cases the main reason behind the date time reset problem occurs due to weak CMOS battery on the motherboard. So, you just need to change your CMOS battery on your motherboard to resolve this problem.
PC HARDWARE
Change the mother board battery it is flat when you change battery you will have to reset BIOS to your time and date
. Also your CPU and memory settings may have to be reset as well
4helpful
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
3answers
When the batteries die I have to reset the date and time again in order to take pics! Was there something that I missed or did wrong?!
The manual states that when you change the batteries, you will have to reset the date and time; this is normal operation for this camera (though it is a pain!!!)
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
