Question about GE Microwave Ovens
The unit stopped heating. The last time this happened I cut the power off at the circuit breaker an it started heating again. This time, nothing. You got any ideas?
    Genius:
  • 3,422 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
Posted on Jul 20, 2008
  • Priya darshan Jul 20, 2008
    This problem requires a physical presence of a tech.There are no home remedies.
  • GE Master
  • 13,433 Answers
It sounds normal, but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Starts a heat food program on its own.
The logic chip is messed up... replace the whole circuit board
Dec 05, 2013 | Magic Chef Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Our Sharp Microwave Model R-508FS has just recently started doing some odd things. If you key in a time and press start, it may continue to microwave but the timer will not count down. Or, if you...
I believe I've solved the problem. I had tried the hard reset but then last night I thought about it and decided that since this house was built 22 years ago, I wondered if the electrician had used the short cut method on installing the sockets for electrical power. So, I measured the voltage at the adjoining socket while heating water. The voltage before turning on the microwave was 122.7 volts. After the microwave was turned on, it dropped down to 107.6 volts. I located the circuit breaker and shut it off and then pulled out the dual socket. Sure enough, they had used the time saving technique of stripping the wire back about 5/8 inch and then pressed it into the back of the socket. I figured it would be better with the microwave pulling 12 amps to just take the wire and wrap it around the screws on the side of the plug, tighten them down and then put it back in the box. Turned the circuit breaker back on and reset the clock on the microwave and did some more tests. No problems so far and when I measured the voltage drop, it went from 122.7 down to 119.7 running at full power. Don't remember the wire size but it was adequate. The only other thing I may try to eliminate any voltage drop would be to go to the master breaker box and tighten down the screw on the breaker going to that microwave outlet. I had tightened them all down in the whole 200 amp box a long time ago, but it probably wouldn't hurt to go thru the whole box again.
Aug 20, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
