Back to:
Tags:
Cars
Generic problem for all Ford Escort Cars
When I start the car
posted by demonsbain on Jul 20, 2008
When I start the car sometimes it will start up no problems and other times it will go click click click click like the battery is dead , yet the battery is brand new. the car is a 1992
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 20, 2008
Helpful (85)
zeusfaber
Rank:Guru Guru
Rating: 86%, 264 votes
If you're absolutely sure the battery is good, then suggest you check all the connections between the battery and the starter solenoid, and between the solenoid and the starter motor. Also check the battery and starter motor earth connections.
Any connection that feels loose, looks corroded, or that gets warm after several seconds' failed cranking attempts is likely to want remaking.
A.
Rating Locked! (?) demonsbain has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on When I start the car:
I don't want to Accept this solution
Can you Help with these Cars problems?
1998 Chevrolet Malibu
The fog lights on my 98 chevy malibu stays on even when...
2003 Dodge Caravan
Dear Expert: I have a 2003 Dodge Caravan, which has only...
1999 Honda Accord
how do i replace an inginiton on a 99 honda accord, it...
2003 Nissan Altima
I am an auto repair novice and wanted to know how to...
1984 Nissan Pickup
the tachometer just stopped working at all in my 84 nissan...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
