Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault 130 what does that mean on a F&P Intuitive washing machine.
Managed to get past if a few times but now im stuck.
Please help.
  • 639 Answers
Dear gink,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
Intuitive Iw509nw fault code 9 what's it mean
the size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Aug 16, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
The model; intuitive eco I need service fault code
RPS fault. this part can easily be replaced. the rotor part of the motor needs to be removed (5/8 socket) then you will see the RPS on the side of the stator. loosen the 4 bolts (3/8), pop it off, replace.
Aug 14, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing machine Intuitive Eco Error 130 then Error 136
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
May 31, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
Aug 03, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault 130 Cold water valve cycling on and off rapidly. On spin, pump cycles on and off rapidly.
Hi just read your posting Now error code 130 means you have a Single Rotor Position Sensor Error.That means the Rotor Sensor which is attached to your motor is faulty or the wires to it are broken.The other fault it could be is the motor controller.The only way to test the Rotor Sensor is with an RPS tester.I can help you test the continuity of the wires that go to the Rotor Sensor if you have or can borrow an electrical test meter.If i had to guess which part is faulty, It would be the Rotor sensor.Hope this helps and please reply for further help.
Jun 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Apr 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
82 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
