Question about Whirlpool RF378 Electric Kitchen Range
Kenmore gas stove
Oven is making popping gas sounds in prheat mode. What could this mean?
  • jshockley5 Jul 20, 2008
    preheat mode
  • jshockley5 Jul 27, 2008
    The stove is now popping throughout the cooking process.
  • Whirlpool Master
  • 5,568 Answers
It sounds like you have some condensation in your gas lines.
The fact that it only does this when preheating kind of reinforces that suspicion.
By the time the oven has reached temperature setting, the bit of moisture has been either blown or baked out of the system.
Steam clouding the window would confirm this or if don't have one, you clould put a shiny pot into the oven and check it for condensation after a few minutes while the popping is taking place.
Posted on Jul 20, 2008
Popping sound in oven when baking
Is something boiling over? Or could be something loose depending on the frequency of the "pop". It could be a fuel control problem. I recommend your gas company service be called. Or an appliance repairman.
Mar 16, 2015 | Frigidaire FGGF304DLW Gallery 30"...
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas burners have a popping sound when trying to heat food in pans
Make sure you clean them properly, Call a repair man if noise persists.
Nov 06, 2013 | Magic Chef 31000 Gas Kitchen Range
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Oven burner makes a popping or whistling sound during baking cycl
You have a gas leak in the oven.
Get this fixed immediately.
Feb 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Smeg Oven blowing
do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Whirlpool RF378 Electric Kitchen Range Logo
318 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
