Hello, Thank You for using FixYa. I will be helping you today. This sounds like a slow drain.I would check the drain where the drain line hooks up.If that checks ok the most likelyculprit would be the drain pump not the timer.
Thank You and please rate my answer if it was helpful..
Hello, Thank You for using FixYa. I will be helping you today. Check the drain line make sure its not too far into the drain or too low or it will continue to drain and fill.
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
I don't work on many Suzuki's so I don't need a service manual. But I believe you will find several at the site below. The site has free PDF downloads. I hope this helps!
Check out your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Some connect to sink, fine. Snaking out your standpipe would be good too.
If the above fails, check to see if your pump is blocked. Pl rate if helped.
make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
