Question about AEG Lavamat 16810 Front Load Washer/Dryer
Waste Pipe I have a new machine and the waste pipe split when trying to install it. I have a new waste pipe but can not see how to replace it as it seems to be routed through the machine - please can you advise how to do this? The model is actually the 16830. Thanks
    President:
  • 1,462 Answers
You haven't said a make and it is presumably a washer but:
waste pipe clips usually onto a spigot on the pump housing. should be accessible by tilting machine backwards. on some machines easier to remove the back plate
Posted on Jul 21, 2008
Fit a new waste pipe?
you need to lay the machine on its side
this is the oposide side from the soap drawer
then under the machine locate the pump and remove the pipe from the pump
must use a spring clip youll need a good set of plyers or a pair of gas grips etc to squeeze the clip open
then the pipe will come out from its hole easily
Dec 04, 2014 | Bosch Classixx WFL 2462 Front Load Washer
How do I change the waste pipe on a dishwasher dw600
follow the pipe iced the machiene and there is a sprung clip like a jubilee clip holding it on ..... you'll need a pair of pliers to squeeze it together
Sep 20, 2014 | Beko Dishwashers
Hoover nextra 8 optima wont drain/empty
check inside the end of the waste pipe, i recently bought a new washing machine and had a similar problem, and checked the waste pipe last. inside the waste pipe was a plug, hope this helps you.
Jun 26, 2012 | Washing Machines
The inlet water does not stop
It could be that your waste pipe is pushed to far down into the drain not giving you an air break between the waste pipe and the water in the bottom of the drain pipe causing the water to syphon out and never allowing the machine to fill to its operating level. raise your waste pipe up until you have an air gap inside your drain pipe and fix it in this positionwith the hose crook that came with the machine or purchase one for a few pence if you have lost it.
Jan 09, 2012 | LG Washing Machines
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
Hi there, my machine won't fill up, but is instead draining. The water is coming out of the waste pipe, instead of filling the drum!
Would your waste pipe be too low OR do you have drain pipe taped tight to waste pipe that can cause siphen..Note waste pipe should be as high as the back of the washer and held in pipe but not taped so no air can get it..If I helped you please vote if you need more help please ask...and good luck
Feb 05, 2011 | Washing Machines
Machine just started leaving dirty water in bottom of machine. cleaned filters,had machine apart,removed and cleaned waste pipe. pump runs and impeller feels ok.only time i could get any water to drain...
Check that the pump is clean and not loose. Make sure pump, impeller, and waste pipe are in alignment with each other and are clean. If it works when you shake the pipe, then there is still a clog inside or the pipes aren't aligned correctly and something is hanging up.
Dec 31, 2010 | Dishwashers
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
E013 error
The feeding screw inside
may be locked because
of an obstacle. Remove
the waste toner pipe,
and try turning the screw
by hand. If it turns
smoothly, install it once
again and see if the
problem has been
corrected. If it does not
turn, replace the waste
toner pipe after
correcting the cause.
Apr 09, 2010 | Canon NP 6545 Copier
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
132 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
