Question about InFocus LP 600 Multimedia Projector
Infocus lp 540
Lamp didn't strike
Also having this problem."Warming up" then "lamp didn't strike" then "retrying" stuck in a loop. It's at a school where I work and nobody has reported any messages regarding the lamp hours.
Posted on Jul 23, 2008
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
Lamp did not strike
You have problem whit the lamp. you should replace the lamp.
Jun 01, 2010 | InFocus LP 600 Multimedia Projector
I have two InFocus LP 540 projectors that simply do not indicate power when they are plugged in. Has anyone else experienced problems with the power supply? Is there a fuse somewhere that might need...
you can check the fuses (located on the power supply board where the cord plugs in), but it's more likely that the caps are dried out and need replacing, or the whole board itself. if that's the case, try av solutions in ny. they're an infocus service center and they're really good. www.avsolutionsny.com
Jan 22, 2010 | InFocus LP 540 Multimedia Projector
Hi, I have an LP Infocus Projector. The fan kicks on but light does not come on. Green light on top keeps flashing, what could be the problem?
it can't strike the lamp. either the lamp is dead or the ballast has dried-up caps. a colorwheel malfunction will also cause the lamp to not strike, but you would get a red led, not a green. if the lamp center has bulges, cloudyness, and/or black spots, replace the lamp. otherwise, you'll want to replace the ballast. you can send it in for repair (or buy the part and do it yourself) from an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
Lamp didnt strike
Hi there
You should reset the lamp timer as this LCD Projector's counter counts down the hours and will not fire up if this has not been done.
If you have reset the lamp timer and the problem stil occurs , you'll have to replace the Ballastboard ( lamp's powersupply )
Yo
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Sep 16, 2007 | InFocus LP 600 Multimedia Projector
Please help
InFocus LP 600 Multimedia Projector Logo
494 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
