Question about Toshiba Satellite P30 P35 Series Notebook
Toshiba P-30 Screen Problem
Right side of display screen, about 1/5th of screen, is a solid white verticle bar. The white rectangle is well defined with a sharp edge on the left side. The other 4/5ths of the screen is normal and shows desktop icons.
  • NoMorTosh4Me
    NoMorTosh4Me Sep 27, 2008
    Same Computer...Same Problem...1.5" vertical white bar on my 17" Toshiba Satellite P35 display...what's the fix?
  • Anonymous Oct 13, 2008
    Vertical line across the middle of the screen, about 1" wide. Yesteday another one appeared to the left of the first one.
  • 2,028 Answers
Well Jim, this could be a couple of things, a simple driver glitch, or a dead pixel area. Let's hope for the driver glitch. Start by uninstalling the video drivers from the device manager, then reboot. The machine will find the screen and reinstall the video drivers. Then readjust the screen resolution in the display properties. If the problem persists, then I'm afraid you have a dead pixel area. This will be caused due to a bad screen inverter or bad screen, then the inverter or screen will have to be replaced. It's very rare, but occasionally a loose or bad connector can cause this. You might also check the screen connections for a loose connection or a little dirt/corrrosion build up.
Posted on Jul 20, 2008
How do you enter mixed fractions?
Look for the key that has the template of a fraction : A solid white rectangle, a fraction bar an an empty rectangle. That key should be between the CALC key and the change sign key (-).
If you press SHIFT followed by the fraction template key the calculator displays the template of a mixed fraction. In the rectangles type in the integer part, the numerator and the denominator. Use the arrow keys to move from one rectangle to the next.
Mar 11, 2013 | Casio FX-115ES Scientific Calculator
Verticle lines on the screen
Failing Display Panel Circuit Board... THis Means You Will Need A Screen Replacement..
Nov 17, 2009 | Toshiba Satellite A105 Notebook
Solid white display
your screen is probley shorted i'm sorry to hear that but you can buy a screen replacement kit off ofebay for around 30 dollars+sh&p
Sep 19, 2009 | Apple iPod MA446LL/A MP3 Player
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
A rectangle with sides parallel to the x-y axes and its left-lower corner at (0, 0) is being painted. The rectangle may be thought of as a flat-screen display with almost infinite resolution; initially the...
It would be "cheating" for anybody to do your "homework" from your computer-mathematics class, unless you submit your answer, saying that an EXPERT on FIXYA did all the work on your behalf.
Apr 14, 2009 | Microsoft Windows XP Professional With...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Yellow verticle bar and blue/yelloe shadowing
You will most definately need to have the convergance realigned... This is a normal thing with projection T.V.s Some T.V.s have a button to push that will allow you to get them somewhat back into alignment but a T.V. pro will need to do the convergance on it if that wont fix it. Hope this helps you out
May 19, 2008 | Sony KP-57HW40 57" Rear Projection...
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Toshiba Satellite P30 P35 Series Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
