Question about Kenmore Elite HE4 Electric Dryer
The PF symbol
This PF symbol keeps coming on and the dryer won't go on.
What is PF?
  • Stephanie Brechbiel Aug 07, 2008
    My dryer is showing the PF error also. I unplugged it from the current outlet and used an extension cord to take it to an oulet in the adjoining room. Dryer still showing PF. Id there anything I can try to check the thermal fuse or other problem?
    Genius:
  • 1,028 Answers
Pf is power failure but may be caused by a control bd issue or bad connection in incoming wiring ,plug or even breaker
Posted on Jul 23, 2008
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
I just plugged in the dryer it has a "PF" message and won't do anything, unplugging dosen't change anything....
Pf is power factor. It is showing you there was an interuption of power. Some models you have to wait at least 3 minutes before you can press stop / pause / cancel to clear the PF. If you still keep getting PF go to the main CB panel and turn off the Dryer CB by physically pushing to breaker to the OFF position to reset the breaker then back to on. You will have to wait again before you can clear the PF. If after resetting the breaker you still get the PF in the display you may have to find out what power you actually have at the outlet. 115V or 230V. Other factors come into play also like 3 or 4 prong connections vs the previous connection. They do make a difference and if the power cord was installed incorrectly the PF will never clear until the cord is connected correctly.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Dryers
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirpool duet dryer stopped working PF signal
PF MEEN PAWER FAUILER SOME HOW YOU LAST POWER TRY TO UNPLUG AND PLUG BACK IN AND PUSH CUNCEL . IT WILL RESET THE BORD IF IT DOSEN;T YOU MAY HAVE A BAD BORD AND IS NOT TAKING COMAND
Jan 20, 2009 | Dryers
Kenmore Elite dryer shows a flashing PF
pf,,power failer...just unplug for 30 seconds,,,
Dec 31, 2008 | Kenmore 659 Electric Dryer
Kenmore 65952 keeps going to "PF"
If you have a receiptical proble loose one leg or ground. This can cause this. If your plug is not in all the way that could show the same problem
Jul 27, 2008 | Kenmore 659 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
508 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
