Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Finding the DZ board
I was wondering does any one know where I can find IC6506 on the DZboard. My tv blinks 3 times only when trying to power on. I received a very quick response to my first question, I found he D board but not the DZ. Thanks again.
    Problem Solver:
  • 12 Answers
Try to check the T603 and R672
Posted on Nov 15, 2008
Panasonic Viera. The TV went off & I got 4 blinking red lights. Installed new power supply. I plugged it in & it made 2 clicks but still will not turn on. I'm still getting 4 blinking lights.Any ideas
Great set - you were on the right track but ........
U will have to do what I did on these new sets. Google has dynamite blogs on the workings of these sets, what each board does, and what are the symptoms of a problematic board. Knowing exactly what your tv is doing and not doing you can use these guides as a wonderful way of finding out what other boards could be at fault besides just your power supply. U have nothing to lose and all to gain with the free info. Good luck.
Aug 31, 2015 | Panasonic Televison & Video
Red Power Light flashes 3 times
3 blinks 3.3v SOS D Board. This is the fault. That's SOS board has the fault. Check this to know more details.
Jan 07, 2013 | Televison & Video
Sony KD-36XS955 Will not power up... Indicator blinks 7 times repeatedly
Please replace 2 ICs on DZ board of tv to solve the issue as discussed in chat session.
Thanks.
Jul 11, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Stand by light flashes 7 times and tv will not turn on
Sony Trinitron Wega KV-34HS420 blinks 7 times it means the the Horizontal Deflection stopped.
There are two cause for this: B overcurrent is detected (IC5007 is defective) or there is a over heating is detected by the Thermistor (TH5002). Both of these parts are on the DZ Board. If you order the DZ Board from the "Partstore.com" it will cost you $395.95 minimum. The Thermistor TH5002 (part # 1-807-796-11) cost $4.95.
This IC chip IC5007 is no longer available at Partstore.com. You could purchase it from other stores. Not sure of price.
Replacing the whole DZ board would for sure fix this problem but at close to $400.00. Then what if another board or your picture tube goes out soon.
Better to go buy a new flat panel LCD from Costco for around the same price.
Hope this helps
Bobby Guel "aka poolmvp1"
May 31, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV36HS500 won't turn on
3 times blinks shows problem of failure of IC6505 in DZ board. If you know basic electronics, open the back cover of tv and go ahead.
Jul 20, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
