Hi, According to your problem you can't print properly with your printer. First check your printer cartridge is not blank. If any cartridge is blank then it may happens. clear the cartridge head. Cartridge may need alignment. Go to the printer preferences and select the Ink cartridge alignment. You can reinstall the driver also. Use dry and proper size of paper which is supported by the printer.
SOURCE: Nothing Prints On The Page
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: prints a line on the page with a blank line
Try cleaning the Printheads (should be accessible from Printer Driver)
SOURCE: lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
